Greg Godon's 69 442 Post
Old March 15th, 2015, 01:54 PM
  #81
rcktdoc's Avatar
Thanks Dave, this car is forsale I have consigned it with Mecum for the spring Indy auction. My other 69 442 post car isnt forsale.
Greg
rcktdoc is offline
Old March 15th, 2015, 01:59 PM
  #82
italian ice's Avatar
Here's the latest batch from Greg.
italian ice is offline
Old March 15th, 2015, 02:14 PM
  #83
rcktdoc's Avatar
The sqwigle on the flex plate is a 6 it is the # that is on almost all the components,rear end,frame,flexplate,gauges, ac box inside,gas tank, dash pad, spare tire etc.
The exhaust manifolds installed with original french locks are near perfect the heat shield is plated the correct phosphate coating.The coil is the correct 216 and the brkt is plated the correct cold galvanizing. The air cleaner was only set on it,still needs to be freshened.
I cleaned the trans today,didnt come out perfect has some staining that wont come off.Trans is original #s match,and was rebuilt about 1000. miles ago So Im not tearing it down,The staines will just have to stay.
Greg
rcktdoc is offline
Old March 16th, 2015, 06:15 PM
  #84
Greg sent these today.
Old March 16th, 2015, 06:16 PM
  #85
and more...
Old March 16th, 2015, 06:49 PM
  #86
rcktdoc's Avatar
Got the air cleaner painted,color is perfect.Installed the trans & back drive. The back drive is plated correctly as is the shift bar that goes to steering column The date is original I just saved it.Trans came out fairly decent not perfect but under the car you wont be able to tell. Got an email today from Legendary my seat covers will ship tomorrow.
Greg
rcktdoc is offline
Old March 16th, 2015, 06:57 PM
  #87
Ryan 1969 Chevelle SS396's Avatar
Is the red breather a 442 item?
PS, I check your progress daily and am very impressed with this build!
Someone will get a new car!!
Ryan
Ryan 1969 Chevelle SS396 is offline
Old March 16th, 2015, 07:47 PM
  #88
rcktdoc's Avatar
Ryan,That is correct for 400 and 350,the snorkels are different between the 2 air cleaners. W cars had a black ram air air cleaner just like yours. Im real pleased with the way its coming out. Im very fussy about how I do things.It would be done the same for myself,a customer or to sell.
Greg
rcktdoc is offline
Old March 17th, 2015, 08:25 PM
  #89
More from Greg...
Old March 17th, 2015, 08:27 PM
  #90
two more
Old March 18th, 2015, 02:07 AM
  #91
rcktdoc's Avatar
Got the firewall finished today, and put the markings back,334 is the interior,52 in the body color.These are exactly as they were. Stripped the radiator and refinished it. Also cleaned up the brk drums and found the Green spray markings,this was only on the one drum,the other had no markings.It was also over the top of the black that they were painted when assembled. Drums will be finished up in semi gloss black and I will duplicate the green marking. Worked on cleaning the floors,this has to be the least desirable job of the whole project ,but when done will have a big impact on how much of a nice original survivor style car this was. Pulled the steering column, not only to paint the firewall but it needs touchup work, as the previous owner had a key chain that scratched up the column.
Greg
rcktdoc is offline
Old March 18th, 2015, 02:26 PM
  #92
Greg's been working every day on this project. Here is the latest batch of pics.
Old March 18th, 2015, 04:24 PM
  #93
rcktdoc's Avatar
Today I got the carb cleaned up and installed,carb almost looks new! Got all the vacuum lines and hoses installed. I finished cleaning and strpping the rear drums Painted them and put the Green Markings back on. Installed the Master & booster,cleaned the Fan clutch and Painted the fan.Will post picks next time of the last items. Getting pretty close to dropping the body back on.
Greg
rcktdoc is offline
Old March 18th, 2015, 05:43 PM
  #94
rcktdoc's Avatar
I need an ac Muffler,does anyone have a nice used one? Please contact me @ ggodon@aol.com or 224-234-3860 Thanks
Greg
rcktdoc is offline
Old March 19th, 2015, 05:07 PM
  #95
Today's update....
Old March 19th, 2015, 05:34 PM
  #96
rcktdoc's Avatar
Got the ac box,WWiper motor,Booster & brk master installed. Used a undercoat just like the factory to seal the ac box,this dries hard and it identicle to what the factory used. In the pics it might have a blue look, it will be competely black when dry.
Greg
rcktdoc is offline
Old March 20th, 2015, 06:43 AM
  #97
from last nite...
Old March 20th, 2015, 12:15 PM
  #98
rcktdoc's Avatar
The ebrake cable is the original cleaned it up and put a preservative coating on it,it was in phenominal condition. Fan and original fan clutch came out real nice but when I looked at it this afternoon the clutch was leaking so I put an aftermarket on it. The ble and silver Harrison sticker is the original that was inside the ac box so I carefully pulled it of and replaced the crappy looking one on the outside.
Greg
rcktdoc is offline
Old March 20th, 2015, 02:20 PM
  #99
rcktdoc's Avatar
Yes I know,thats why it realy dissapointed me when it started leaking. Thanks for the compliment.
Greg
rcktdoc is offline
Old March 21st, 2015, 03:54 AM
  #100
rcktdoc's Avatar
Finaly got around to the drive shaft yesterday. Started stripping it and found that it was painted black from the factory,not sprayed at the end of the assy line but painted black before it was installed. The input shaft (yoke) also had some markings that I had never found before. Will post some pics later. This car being as original and well preserved as it was has been a wealth of knowledge.
Greg
rcktdoc is offline
Old March 21st, 2015, 06:21 AM
  #101
costpenn's Avatar
Greg
Greg, where was this car built?
costpenn is offline
Old March 21st, 2015, 10:13 AM
  #102
rcktdoc's Avatar
This is a Fremont car, So Im sure that there are a lot of differences from the Lansing plant but most of the plateing on bolts,shielding,bracketry etc are the same from plant to plant.
Greg
rcktdoc is offline
Old March 21st, 2015, 10:16 AM
  #103
Greg
Old March 21st, 2015, 10:17 AM
  #104
more
Old March 21st, 2015, 10:19 AM
  #105
last few
Old March 21st, 2015, 04:33 PM
  #106
rcktdoc's Avatar
Finished the drive shaft and installed it,Got the rest of the front of engine assembled and the battery cable tube.Worked a little on the floors,cleaning them has been a pita.
Greg
rcktdoc is offline
Old March 22nd, 2015, 01:49 PM
  #107
Today's progress
Old March 22nd, 2015, 01:50 PM
  #108
one more
Old March 22nd, 2015, 02:39 PM
  #109
Very nice work, impressive. Are you going to replace to replace the Carquest oil filter?
1969w3155 is online now
Old March 22nd, 2015, 04:35 PM
  #110
rcktdoc's Avatar
It was only on to seal up engine to prime it and for initial startup.Once the engine is broken in It will be replaced. Dropped the body on today, will finish buffing the fenders and the rest of car tomorrow.My seat covers from legendary shipped Friday so Im hopeing by weds I have those. Still need a few things but its comeing along well.
Greg
rcktdoc is offline
Old March 22nd, 2015, 04:39 PM
  #111
If you need a blue AC oil filter, I have one.
Old March 22nd, 2015, 06:02 PM
  #112
rcktdoc's Avatar
Thanks,I appriciate the offer, I have an emboised assembly line white filter I may use. If I decide to keep it for my other post car I may take you up on it.
Greg
rcktdoc is offline
Old March 23rd, 2015, 07:34 AM
  #113
jstrits's Avatar
Nice work greg, although you know that already. Through the years of self teaching myself to do cars there are things to be learned the right or wrong way. I always love to look at the work of all the other shops out there. I will say that greg and his son rank at the very top. If someone is serious about having a car done I would point them to these two. Alot of times the best jobs come out of the places youy'd least expect. But with that said, knowing greg one would expect no less. jason.
jstrits is offline
Old March 23rd, 2015, 07:36 AM
  #114
jstrits's Avatar
Greg
I have a nos 70 muffler/hose is that the same?
jstrits is offline
Old March 23rd, 2015, 10:32 AM
  #115
rcktdoc's Avatar
Thanks Jason,your kind words are greatly appriciated. Give me a call Im pretty sure the 70 is the same. Thanks
Greg
rcktdoc is offline
Old March 23rd, 2015, 01:00 PM
  #116
jstrits's Avatar
Greg
email sent with a picture
jstrits is offline
Old March 23rd, 2015, 02:12 PM
  #117
rcktdoc's Avatar
Jason, got it sent back a reply. Thanks
Greg
rcktdoc is offline
Old March 23rd, 2015, 06:33 PM
  #118
Only one pic update today..
Old March 23rd, 2015, 06:43 PM
  #119
Great progress, fun to watch!!
Ryan
Old March 24th, 2015, 02:38 AM
  #120
rcktdoc's Avatar
Got a lot of small things done Yesterday, just nothing worth taking a picture of. Seat covers are sceduled to be delivered today. I dont have the positive battery cable, but I think Im going to put the old one in and start it before I hang any sheet metal. God forbid there should be any issues its easier to fix now than after the front end is assembled. Its easier to replace a battery cable than to try fixing it with all the front end assembled. At this point I have a little over 700 hrs in this restoration,that is working 12-16 hrs a day since around the 20th of January, and this was an exceptionally nice car but I also have done every aspect of this restoration from the begining, with the exception of blasting the frame and other small components.
Greg
rcktdoc is offline
Quick Reply: Greg Godon's 69 442 Post
