Like night and day...
Old October 12th, 2019, 08:46 AM
72455's Avatar
Cleaned up my master cylinder today ..took about 30 min and some elbow grease.
72455 is online now
Old October 12th, 2019, 06:42 PM
oldsmoboogie's Avatar
Looks good, what did you use?
oldsmoboogie is offline
Old October 13th, 2019, 09:19 AM
Gee that cap and bale turned out nice and shiny Great job on the master. I'm guessing something like CLR
Allan R is offline
Old October 13th, 2019, 10:33 AM
72455's Avatar
Ok...I'll share my secret, but first, the master is an aftermarket swap I did over the summer ( and, yes, I kept the original to rebuild)😁 So getting the cap and bail shiny was easy..just some metal polish and elbow grease😁
As far as the master, it was mainly surface rust, so a wire brush took care of most of that. Then I sprayed it with WD40 and let it soak for a few minutes. Wiped it down, sprayed some WD40 on a cloth, and wiped it on, and that was that..easy peazy...now it's simply a matter of maintenance 😀
72455 is online now
Old October 13th, 2019, 02:25 PM
Wow, your humidity and heat down there are brutal on metal aren't they? I took a master off my car this past fall that was installed back 6 years ago, and it still looked like the one you cleaned up. Problem is it failed and was leaking from the piston end. Cheaper to replace than rebuild. Rockauto is good for that.
It looks just like the AC Delco one I put on.
Allan R is offline
Old October 13th, 2019, 06:31 PM
Looks great.
oldcutlass is offline
Old October 13th, 2019, 06:50 PM
FN723's Avatar
I normally paint mine with cast paint so it stays looking like that.
FN723 is offline
Old October 14th, 2019, 08:12 AM
72 Olds CS
RetroRanger's Avatar
That looks much better, I did the same w mine 2 years ago. Also got a slight case of the MAWs and bought the Eastwood MC paint. I was super happy w the paint went on nice and looks good. I'll post a pic when I get a chance.
RetroRanger is offline
Old October 14th, 2019, 11:39 AM
Hmmmm, more I think about it, I like the 'patina' look better. Change it back. Just throw some clear on it and call it good.
Allan R is offline
Old October 14th, 2019, 07:33 PM
72455's Avatar
Allan has jokes...🤣😂🤣
72455 is online now
senginc
June 2nd, 2019 07:25 AM
Toms65
June 22nd, 2018 04:44 PM
Toms65
March 3rd, 2018 05:14 AM
jaunty75
July 17th, 2013 12:59 PM
Mr Shifty Sidney
June 12th, 2013 12:06 AM
Quick Reply: Like night and day...
