New Project 67 Trac Pac
Old January 14th, 2010, 02:18 PM
Oldsmaniac's Avatar
Am quite excited to find that a 67 442 I purchased sight unseen from a non Olds guy is a Trac Pac. No mention of this was given and the car needs quite a bit but is solid. It's a post car, plain jane, 4spd, bench seat, manual steering and brakes.
Oldsmaniac is online now
Old January 14th, 2010, 02:24 PM
Oldsmaniac's Avatar
A few more pictures.
Old January 14th, 2010, 02:28 PM
67 Cutlass's Avatar
Nice find. Good luck with the rebuild. Looking forward to the build thread
I saw one on evilbay almost like yours... http://cgi.ebay.com/ebaymotors/1967-...item255839ecdd
67 Cutlass is offline
Old January 14th, 2010, 04:24 PM
citcapp's Avatar
Looks like a great project to spend these long winter months on. You won't be bored thats for sure.
citcapp is offline
Old January 14th, 2010, 04:25 PM
Just curious, how do you know that it is a trac pac car?
1969w3155 is offline
Old January 14th, 2010, 04:51 PM
Trying to remember member
wmachine's Avatar
Great project, Joe! A great car to "save" and restore!! Keep the progress reports coming.....
wmachine is offline
Old January 14th, 2010, 04:58 PM
Getting There
Ranzan's Avatar
trac pac car!!!! I was droolin before with a post car....
Ranzan is offline
Old January 14th, 2010, 05:03 PM
Govt slave
squirell's Avatar
Nice score if it's really a trac-pac !!
Shouldn't a 4sp car have 2 red and 2 white tailights though ?
squirell is offline
Old January 14th, 2010, 05:07 PM
Lady72nRob71's Avatar
Nice save! But what's a trac pac?
Super stripped down for super light weight and along with some other go-fast goodies??
Ejukate me!
Lady72nRob71 is offline
Old January 14th, 2010, 05:16 PM
wmachine's Avatar
Taillights have nothing to do with the transmissions, it has to do with what model it is. All Cutlass Supremes have all 4 red tail lights and separate backup lights in the bumpers. The Cutlass and F85 models have the backup lights in the lower 2 taillights.
wmachine is offline
Old January 14th, 2010, 05:34 PM
Oldsmaniac's Avatar
A Trac Pac 442 would be either a dealer or customer installed performance package available thru Olds dealers that contains nearly all of the W30 package items. The cam, valve springs, components for battery relocation, OAI components, clamps, grommets, etc were in this package. The pictures posted show evidence of this car having the Trac Pac package installed on it along with a few other items that came with the car and tell-tale signs. While hard to document the tell-tale signs are pretty convincing. Very few Trac pac cars remain. Trac Pac cars would not get chrome valve covers, red inner plastic wells or a chrome oil fill cap.
Old January 14th, 2010, 05:38 PM
Govt slave
squirell's Avatar
Thanks for the education
squirell is offline
Old January 14th, 2010, 05:58 PM
Shoveling Snow
Hairy Olds's Avatar
One of the easy ways of checking if it was a trac pack or W-30 is to look at the drivers side core support and see if the area is rotted. The core support should be in good shape because the battery was in the trunk.
The shroud is going to look great on the car.
Hairy Olds is online now
Old January 14th, 2010, 06:22 PM
Oldsmaniac's Avatar
Picture 4 in the first group shows very little rust/rot where battery tray originally was. Three holes are in the trunk and line up perfectly with correct battery tray. Area there is rustier than the front fenderwell. It was told to me that most Trac Pac installations were done one to two years after car was sold new. After speaking with and sending pictures to a couple of very knowledgeable people concerning this car they were convinced that this is a Trac Pac 442. The car has been off the road in a barn since the late 80's. I can agree to this by the amount of mice nests found!
Old January 14th, 2010, 08:06 PM
Run to Rund's Avatar
It is obvious that the baffles on the sides of the radiator core support were cut and drilled for OAI ducts. It is also obvious that they were cut the "home made" way, not factory stamped, therefore it is a track pack not factory production line car. Also the holes in the floor covers in the trunk are offset on this car, centered on factory cars. There are more things to look for like holes in the vertical of the left frame rail in the "open" or C section part where the battery cable was retained. The key thing here is to acquire original or reproduction OAI parts and restore the car to its former glory!
Run to Rund is offline
Old January 15th, 2010, 05:03 AM
wmachine's Avatar
You bet!
Also:
Obviously, the most obvious W30 part the TP cars didn't get was the red inner fenders. Of course not red, but it does look like you have plastic inners. Yes?
wmachine is offline
Old January 15th, 2010, 05:47 AM
Oldsmaniac's Avatar
Yes it will, an awesome piece, paid more for that than I did the car
W Machine, thanks, will be in touch....inner fenderwells are metal but in great shape.
Old January 15th, 2010, 10:32 AM
Nope, I can see they are black steel inner fenders.
Old January 15th, 2010, 05:25 PM
wmachine's Avatar
Black plastics would be an interesting touch...........
wmachine is offline
Old January 15th, 2010, 05:29 PM
Oldsmaniac's Avatar
Years ago I was in a junkyard and passed by a 67 Vista with the fenders removed.....the fenderwells were black plastic!! Still kicking myself over not grabbing them!
Old January 16th, 2010, 06:19 AM
MN71W30's Avatar
Right here in Minnesota? Dang, I missed out on a nice car. Good luck on the restoration.
MN71W30 is offline
Old January 16th, 2010, 03:50 PM
Oldsmaniac's Avatar
Yep I drug it back to NJ, 1350 miles each way. Although solid it needs TOTAL resto...came with a lot of missing pieces, bad pieces, and incorrect pieces.... Oh, 2 engines in pieces, neither one correct, a peg leg 69 pontiac rear, and a chevy muncie with a cracked case. Its a good thing most of what I need can be found in my parts stash!
Old February 14th, 2010, 06:44 PM
Oldsmaniac's Avatar
A little progress and a purchase.....OUCH!
Old February 15th, 2010, 03:45 AM
70vista's Avatar
Very nice project you have there. It's nice to see history being preserved. Good luck and glad the car found a good home.
70vista is offline
Old February 15th, 2010, 02:17 PM
Oldsmaniac's Avatar
Thank you to everyone for the support and encouragement. Still a long way to go.....
Old February 15th, 2010, 02:27 PM
Shoveling Snow
Hairy Olds's Avatar
Boy that air cleaner looks real nice. Where did you get the ducts from?
Old February 15th, 2010, 02:35 PM
Oldsmaniac's Avatar
I got the bezels years ago from Curt Anderson. I think they are still available from him. I need a source for the brackets that hold the hoses to inner fender.... I mailed one guy on a lead and no reply at all....
Old February 15th, 2010, 02:47 PM
wmachine's Avatar
Mike Siedlik (http://www.thegoodoldsdays.com/)?????
You can always fab up a pair if need be.
wmachine is offline
Old February 15th, 2010, 03:46 PM
therobski's Avatar
Beautiful "post" project Like my 64 it's going to take alot of patiance and $$$$$ to bring these back. My 64 is going to be a "granny sleeper" street machine. Did the 400E come with it? Let me know if you need any parts. As many know my 67 442 is a resto-mod VERY non-original, but have some original parts in boxes. DSCN2119.jpg
therobski is offline
Old February 15th, 2010, 04:27 PM
Oldsmaniac's Avatar
That 64 is going to be a great plain jane-er.....no the 400 is gone, would like to put one in there but the prices are not in my budget right now. Just need a block.... I will be using a 67 425. the car came with a rusty 65 400 and a 70 455. Neither one appropriate in my book.
Old February 15th, 2010, 05:01 PM
  #31
therobski's Avatar
Are you not going to put the car back to original? A Trac-Pac POST is very unusal. But if you want to pound and cruise I fully understand that's why I am building my cars 64 and 67 (except for the Vette) my way to drive to the Saturday night burger joints or pack it up and go on the "Power Tour" in Vintage A/C comfort. I actually broke in my built 461 in the 67 on the 08 Power Tour. My old 67 400E is going in my 64, imagine a 400E maybe with L69 Tripower? With a 200R4 etc. DSCN1723.jpg
Old February 15th, 2010, 05:32 PM
  #32
Oldsmaniac's Avatar
Interesting, the original 400 out of my convert went into my brother's 64 post but has since been pulled for a 455. The 400 sits in the garage as it belongs in my convert. The 67 post will be as original because that's the way I like em but will have a few things not quite 100% such as wheels, tires, etc I am not fond of the painted rims with dog dishes even though thats prob what the car came with.
Old March 6th, 2010, 07:16 PM
  #33
Oldsmaniac's Avatar
A little more progress, the 390 posi is in!
Old March 7th, 2010, 03:34 AM
  #34
therobski's Avatar
What trans did you use when you had the 400 in the 64 post? This 64 is a major project that I have never taken on primarilly because it need floors and a trunk. Looks like your moving along on your project. Keep up the good work.
Old April 5th, 2010, 06:40 PM
  #35
Oldsmaniac's Avatar
Only a few more pictures, restored steering wheel, patched shifter hole, fixing rot on back glass area.
Old April 5th, 2010, 06:52 PM
  #36
car guy
gearheads78's Avatar
Great piece of history to restore. So what's the going rate on plastic 67 fender wells? I happen to have a pair.
gearheads78 is offline
Old April 5th, 2010, 07:00 PM
  #37
Oldsmaniac's Avatar
Original red plastic 67 wells would be pretty desireable I would think but only came on factory w30 cars and not trac pac cars. They are reproduced as well and the Parts Place sells em. Plain black plastic wells are repoped too and originals would be favored over repops if in good shape. I usually put my stuff on ebay and let the world decide the value.
Old April 5th, 2010, 07:31 PM
  #38
Registered Luser
ent72olds's Avatar
Keep up the good work!
ent72olds is offline
Old April 5th, 2010, 07:51 PM
  #39
Getting There
Ranzan's Avatar
It`s coming along nice......
how much rot is in the car? it doesn`t seem to be too much
Ranzan is offline
Old April 5th, 2010, 08:33 PM
  #40
Oldsmaniac's Avatar
Not too much rot and by that I mean none in floors or trunk floor. Small amount of rot in usual places, around front and rear glass, one quarter under wheelwell trim, one front fender. No rot in doors or rockers. driver's side quarter, door, fender have been changed most likely due to a accident/sideswipe and thats why no rot there.
Quick Reply: New Project 67 Trac Pac
