Next Project - 67 442 4-speed
Old October 25th, 2011, 05:23 PM
Navy P-3 FE (Ret.)
67Olds442X2's Avatar
Now that my engine is holding out, it might be time to start the next project.
I have a good car to start with and it's already taken apart. Time to start the clean up and reassembly. Once the body is off I'll start with the frame.
This car will go back together stock because everything is there and I believe the drive train is original.
67Olds442X2 is offline
Old October 26th, 2011, 04:33 AM
Chesrown 67 OAI's Avatar
Nice car -- keep us informed with pix of your progress/.
Chesrown 67 OAI is offline
Old October 26th, 2011, 06:12 AM
Very solid start for a project!! Are you going back stock?? Whats the plan?
oldcutlass is offline
Old October 26th, 2011, 07:04 AM
TK-65's Avatar
Looks pretty solid.
TK-65 is offline
Old October 26th, 2011, 03:35 PM
Navy P-3 FE (Ret.)
I'm going to keep it stock. Might build a 455 for it but nothing extreme. Will have the 400 built stock.
Old November 26th, 2011, 09:52 PM
Navy P-3 FE (Ret.)
Been slow going for sure. Yanked engine and trans, tore engine apart. Was going to remove body but I have no space and I won't leave my other car outside so I guess it'll be a body on resto. Will raise it high enough to get underneath to clean what I can and paint. Will at least change the body mounts. Starting with the front end and work back I guess. The passenger floor needs a patch and the windshield and back window areas are rusty. Rear quarter panels have holes on the bottom which I'll patch. Otherwise pretty solid car.
Old January 14th, 2012, 03:11 PM
Navy P-3 FE (Ret.)
Still slow going. Took a good look in the trunk area and may need more than I originally thought. I drilled holes to get access to the body mounting nuts so I can soak them before removing the bolts. The right side mount next to the wheel well is rusted through out. Both sides have been patched before so I'll be working on my welding skills which are non existent now. Since my working space is well very limited, I'll try to raise the body as high as I can supporting it on 4x4's using the tall jack stands I got. I'll then lower the frame onto dollies to roll it out. I'm removing the differential first since it belongs to the white car. Don't know if a rotisserie will fit if I get one. I guess having it supported with the 4x4's should work. I've seen worst setups.
Old January 15th, 2012, 11:44 AM
L69
L69's Avatar
Nice car Dan, looks solid.
L69 is offline
Old January 20th, 2012, 07:16 PM
Navy P-3 FE (Ret.)
Just some more disassembly pictures. Under side is a little rustier than first thought. 5 mount bolts out so far with 1 broken. Body mount bushing aft of axle on right side rusted through. It'll be interesting to see if I can do this body off in the space alloted.
Old February 4th, 2012, 09:55 PM
ah64pilot's Avatar
Dan, it looks like a solid project car. Glad to see you got the engine issues worked out on the other one. Take care!
Steve
ah64pilot is offline
johnny5
April 10th, 2012 09:04 PM
bil
October 5th, 2010 08:24 AM
cutlassgal
March 31st, 2010 07:21 AM
gearheads78
December 6th, 2009 11:37 AM
Redog
Bravada
September 20th, 2008 10:49 AM
Quick Reply: Next Project - 67 442 4-speed
