1955 Oldsmobile Heater
Old September 27th, 2012, 07:30 PM
ajohm's Avatar
In the middle of this picture you see what appears to be a heater outlet of some sort. I didn't take this car apart and have no idea what this is supposed to be hooked up to?? Any help will be appreciated
ajohm is offline
Old September 27th, 2012, 08:20 PM
Collector of Stray 55's
Olds Dad's Avatar
I assume that this is at the bottom of the heater box assembly...that is a drain - water from the cowl area that would get into the heater box would drain out there - there is a rubber drain tube that is missing (but not necessary - just drained to the ground) - Fusick has the tubes if you care, but you don't need them. There's one on the driver's side air box as well.
Looks like the spring clamp that used to hold it on is still there.
Check this thread to see what the assembled box looks like (note that the drain tubes aren't attached in those photos)
https://classicoldsmobile.com/forums...storation.html
Hope it helps
Olds Dad is offline
Old September 27th, 2012, 08:50 PM
ajohm's Avatar
Hope it helps
it does help, thank you!
ajohm is offline
5998DownUnder
June 9th, 2014 09:35 AM
drftsub
June 7th, 2011 11:50 AM
toyktdlgh
June 2nd, 2008 05:52 AM
malatu
April 27th, 2008 04:52 AM
Tedd Thompson
April 12th, 2008 05:24 PM
Quick Reply: 1955 Oldsmobile Heater
