1968 442 4speed hurst shifter
hello every one well first of all i got to say thanks everione 4 you good help i got a new problem my car came with a 4 speed hurst shifter so i installed it on the car but the car only drives forward the reverse is not engagin so what could
b the problem should i send the competition plus shifter for a rebuilt or the reberse rod is too long/////
With the rear wheels off the ground, have someone press on the clutch while you see if you can manually engage reverse in the trans using the lever on the side of the trans (with the rod to the shifter disengaged). Start the engine and see if the wheels turn in reverse. If so, the trans if fine, if not that's your problem.
Once you've determined the trans is OK and the shifter goes into reverse and moves the correct lever on the bottom of the shifter mechanism, you need to check alignment and adjustment. First thing to be sure of is do you have the three levers on the bottom of the shifter aligned properly when in neutral. There is a small hole in the mechanism and the three rods. You should be able to insert a 1/4" drill bit or rod all the way through to lock the levers in the neutral position. NOW install and adjust all three linkage rods. Be sure you have the correct rods on the correct levers. Pull the alignment pin and all should be working.
Its a hurst competition plus shifter i dont knw if its the correct shifter for my application but the car came with a munci 400 i will try and do what you suggested thanks joe is there any chance that my shifter is not good it seems to engage everi gear fine...
The Competition Plus is a very simple mechanism. If the shift handle goes into each of the three gates and the appropriate levers on the bottom move when they are supposed to, it's probably fine. They need rebuilding when they get sloppy, but usually that just means that they hang up when power shifting, they rarely don't go into gear. The factory shifters have a snap-in chrome stick, the aftermarket have a bolt-on stick. The factory shifter stick will have the letter "H" and "442" stamped on it. If you have a snap-in stick that doesn't say "442", it's not the original shifter.
Out of adjustment is FAR more likely than a bad shifter. Factory rebuilds the shifters if that is a problem.
Maybe the tang or ear on the trans is on upside down and the shifter is trying to move it the wrong direction? Separate the shifter action from the trans action [in other words, remove the rods as need be] and verify that each works right by itself.
Make sure the transmission levers are in the "up" position. They should not be pointed down. Up, ok? Now hook up your linkage rods and give it a try. Let us know what happens. If you have them facing down the trans will still shift, it just has a reverse pattern. 4th is first, second is third, and so on.
Dude my vin #starts with a 344878 so that means its a true 442 but i dont knw why it didnt had a 442 shifter no big deal .. Ok back to the topic so the two long rods suppose to be facing down and the smaller one suppose to be facing up no wich is the reverse rod??
The tabs on the trans need to be in the up position before you put the rods on them. You can see them in the pic. Forget about the rods for a second. Look at how the tabs are that the rods connect to. They are up. You can install them facing down. Did you mistakenly do this?
Guys am so happy to let all of you knw that the problem is fix thank you all for your help it was very usefull i really appreciate it the car is finally runnin ine of the rods was too short and the reverse is hard to find but we finally did it..
gearheads78
August 27th, 2015 07:13 PM
marxjunk
June 12th, 2014 12:34 PM
Nickyloves442s
September 26th, 2013 02:19 PM
88hurstolds
August 20th, 2013 11:22 AM
