1971 Cutlass Supreme just purchased as is
Old August 6th, 2022, 11:20 AM
exhausted's Avatar
Other side similar
Other side similar
Car rides and drives ok, front end loose. Low oil pressure. Previous owner said original owner had a cam replaced and may have contributed to low oil pressure condition. Been mostly sitting since 06, driven + or - 200 miles according to previous owner. I'm not sure which direction to go with this car....
exhausted is offline
Old August 6th, 2022, 11:22 AM
exhausted's Avatar
Interior of 71
Old August 6th, 2022, 11:25 AM
Rocket Renegade!
Well, seeing as it's a fairly common item and it looks like you'll be pretty much bringing it back from the dead, I'd say you have a blank slate. What do you like best?
BangScreech4-4-2 is online now
Old August 6th, 2022, 11:58 AM
Welcome and congratulations on the car. Right model and right color! But I may be a bit biased.
Fun71 is offline
Old August 6th, 2022, 12:09 PM
I'd first establish a goal - daily driver, full restoration (rotisserie), etc. Establish a budget. How much you going to do yourself &/or shop out (budget). Based upon budget write out a couple plans on paper (or otherwise; e.g. Excel spreadsheet, Word, notepad - whatever) under select categories: i.e. suspension, engine, transmission, body work, brakes, electrical, AC, interior upholstery, etc. Add prices of replacement pieces along the way. Nice project car.
Vintage Chief is offline
Old August 6th, 2022, 12:36 PM
Cool car. Great colors. I love a Supreme. I love that it is a survivor. Clean it up. Give it what it needs and enjoy it. 👍
no1oldsfan is offline
Old August 6th, 2022, 12:40 PM
Congrats, welcome to the site.
oldcutlass is offline
Old August 6th, 2022, 01:28 PM
'70 4-Speed W Machine
tnswt's Avatar
Welcome. Is that a tach mounted on the hood or heat gauge?
tnswt is online now
Old August 6th, 2022, 01:42 PM
I caught that earlier, also. I'll bet it is. Have to love ingenuity - whatever it takes.
Old August 6th, 2022, 02:20 PM
70W-32's Avatar
Its an oil pressure gage. You can see the feed line going to the oil port in the one underhood picture
70W-32 is offline
Old August 6th, 2022, 02:23 PM
70W-32's Avatar
I think youve picked up a nice project/driver. Make the car safe(suspension/brakes), then decide which way you want to go
70W-32 is offline
Old August 6th, 2022, 04:39 PM
'72 Cutlass ragtop
70sgeek's Avatar
If you are decided on keeping the car, I'd try to figure out what the low oil pressure issue may be - fully tune the motor up (new plugs, wires, cap/rotor oil change, air/fuel filters, coolant flush, etc.), maybe run 15w-40 oil when you change it, to see if that brings the pressure up a bit temporarily. Also replace the oil sending unit on the block for good measure (they're cheap but make sure you get the correct one - different units for factory dash gauge vs. warning light)
I'd also suggest replacing the battery cables and voltage regulator (if still the external part) - originals are way past their safety limits at this point.
Otherwise agree on replacing chassis related items first - suspension, brakes, steering. Replace the fuel pump, gas tank (new aftermarket pricing fairly reasonable) and sending unit.
Assuming it has 14" wheels, consider moving up a size ito at least 15" so you can comfortably upgrade to front disc brakes if it doesn't have them, or at least for a better tire selection.
...and the beat goes on!
70sgeek is offline
Old August 6th, 2022, 05:17 PM
If you note in the pictures and discussion above, there is a mechanical oil pressure gauge.
Fun71 is offline
Old August 6th, 2022, 06:05 PM
Tj Pal's Avatar
Welcome!
Tj Pal is offline
Old August 6th, 2022, 11:51 PM
exhausted's Avatar
Thanks to all for your suggestions and welcomes! I'll post as things develop....
Old August 7th, 2022, 03:24 PM
'72 Cutlass ragtop
70sgeek's Avatar
I just looked at your photos again and noticed the loose dash chrome trim
you can replace it with OPGI's full kit (new strip and clips) pretty cheaply
Molding, Dashboard, 1970-72 Cutlass, Chrome @ OPGI.com
70sgeek is offline
Old August 8th, 2022, 02:22 PM
exhausted's Avatar
Thanks for the tip on the dash trim!
Old April 7th, 2024, 02:52 PM
Fonz's Avatar
Definitely get rid of that" PLASTIC Oil Line" ! Replace it with "COPPER". ! the plastic WILL break and might cause a fire !!
Fonz is offline
Old April 7th, 2024, 03:50 PM
While your recommendation is good, it's highly doubtful the OP will see your recommendation since their last on-site activity was nearly two years ago - October 21st, 2022 02:49 PM.
Old April 7th, 2024, 07:29 PM
Additionally, the nylon line “MIGHT” break. Mine has not failed since it was installed in the 1980s.
Fun71 is offline
Old April 7th, 2024, 07:35 PM
Loaded68W34's Avatar
Given where that oil gauge is mounted, I would say their is much more danger of stressing copper tubing past its fatigue strength by opening and closing the hood then there is with a plastic line. Not that it matters since this thread was long dead anyway, but given the location of that oil gauge, the best bet would be an AN braided line.
Loaded68W34 is offline
no1oldsfan
May 1st, 2021 11:38 AM
j808702
October 11th, 2017 04:23 PM
j808702
November 16th, 2016 07:50 PM
j808702
October 26th, 2016 07:19 PM
kevin442
July 27th, 2009 07:44 PM
Quick Reply: 1971 Cutlass Supreme just purchased as is
