455 rebuild. cannot get good idle and it stalls. Help!
Old April 2nd, 2015, 05:57 PM
Jefft's Avatar
I recently swapped built a mild 455 to swap for my 71cutlass’s 350. After the swap I cannotget the beast to idle very well. It is 30 over and other than installing anupdated cam and HEI ignition.
HydraulicFlat Tappet Cam. Good cam for street performance. Works with stock converter,headers and needs lower gearing with 350 c.I. motors. Good idle.
· AdvertisedDuration (Int/Exh): 275/275
· Duration@ .050 (Int/Exh): 225/225
· GrossValve Lift (Int/Exh): .508/.508
· LSA/ICL:108
· ValveLash (Int/Exh): Hyd/Hyd
· RPMRange: 1600-5500
· Includes:Cam & Lifters (#71951PR-16)
With the vacuum line plugged and at 650 RPM I time atbetween 9 and 10 degrees. When I connectthe line back to the vacuum control switch the engine pops up to about 1100 RPMin park. I put it in drive and the RPM drops to 600. After the engine heat s up and pull to a stopthe idle drops to 500 and then will stall out. I was always under the impression that thereshould be no vacuum advance at idle. AmI mistaken? I am pulling the vacuum fromthe Q-jet port to the right of the fuel line. Any help would be appreciated.
Jefft is offline
Old April 2nd, 2015, 06:56 PM
Justin
oldstata's Avatar
So with hei your timing is 9-10 initial timing ?
I think you should be at 12-15degrees if, I am not mistakin with the vac advance unplugged and capped.
I am no expert, so I will let others chime in and correct me if I am wrong
oldstata is offline
Old April 2nd, 2015, 07:10 PM
Chevy budget Olds powered
coppercutlass's Avatar
Shoot for 14 16 initial , and run your vac. Adv. From an ported source. Start there. Then start looking into adjusting fast idle and your idle mixture screws and what not. If you are poping up to 1100 rpm at idle your advnce is hooked up to an unported source.
coppercutlass is offline
Old April 2nd, 2015, 10:33 PM
Redog's Avatar
Your timing is way off.
I always thought the Olds motors ran best at 20* advanced at 1100RPM's
Redog is offline
Old April 3rd, 2015, 04:08 AM
I would leave the vacuum adv line disconnected and plugged until you get your timing sorted out. Your initial timing is definitely not advanced enough.
oldcutlass is offline
waterzap
February 12th, 2014 12:56 PM
pcard
February 28th, 2013 06:58 AM
Seff
September 20th, 2012 04:46 PM
73rocketship
July 6th, 2012 06:45 AM
jazagain
February 12th, 2007 02:26 PM
Quick Reply: 455 rebuild. cannot get good idle and it stalls. Help!
