'70 olds cutlass, widest tire up front 15" rim ?
Old January 26th, 2018, 08:49 AM
Johnnylindo's Avatar
newbie here, just picked this up, hoping someone can help I want to go wide as possible up front, looking for a low level stance stock car oval track look,with wheels tucked nicely inside wheel well. The rear is tubbed and currently has a 31x16.5 tire on a 15x12"rim with a 5.5 backspace. I'd like the rear tires to fill the wheel well even more, I have at least 2"inside and outside to work with. I'm thinking 15x14 rim with diameter around 28". Hope the pic attaches
Johnnylindo is offline
Old January 26th, 2018, 09:08 AM
Why all the info on the rear tires when the thread title is asking about the front tires?
Fun71 is offline
Old January 26th, 2018, 09:14 AM
Welcome to the site, I fixed your picture. Nice ride. What size wheel are you running up front?
oldcutlass is online now
Old January 26th, 2018, 09:40 AM
Wheels
Sorry not so fun71, I left out back wheels, it's been frustrating trying to figure this all out, I'm not very savvy with computers , thanks for the welcome oldcutlass, up front are 165-80-15
Old January 26th, 2018, 09:43 AM
stevengerard's Avatar
I believe I have 245 60 15 on the front and they rub occasionaly when turned to lock and going up an apron or other steep incline.
stevengerard is offline
Old January 26th, 2018, 09:44 AM
S
Sorry Weld wheels
Old January 26th, 2018, 10:17 AM
I've run 255/60-15s in the front on stock rims with zero offset.
joe_padavano is offline
Old January 26th, 2018, 10:19 AM
Steve and joe, what is your rim size? Width?
Old January 26th, 2018, 10:22 AM
Sorry, I should have added that. 15x7, zero offset.
Old January 26th, 2018, 11:14 AM
So I got a 15x7 on a stock rim with zero offset and a 15x8 with a 5" back space that may work hmmmm
Old January 26th, 2018, 05:12 PM
I wasn't sure exactly what you were asking before.
I also have 245-60-15s on factory SSIII wheels, and have not had issues with rubbing. There seems to be plenty of clearance all around. Back in the 80s a tire shop inadvertently put one 255-60-15 on the left font and it rubbed slightly during turns. You may be able to get away with 255s depending upon your suspension setup - mine was factory original back then, so maybe sagging a bit.
Fun71 is offline
Lsx442
Wheels and Tires
February 4th, 2024 02:58 PM
rocketbob54
July 31st, 2016 07:09 PM
MDchanic
Wheels and Tires
22
August 4th, 2011 10:23 AM
81 regency
April 21st, 2011 06:18 PM
jtriggy
Wheels and Tires
February 22nd, 2010 05:47 AM
Quick Reply: '70 olds cutlass, widest tire up front 15" rim ?
