Changed timing chain now car won't start
Old April 4th, 2020, 10:10 PM
  #41
Uhh, yeah I think I see the issue. It appears that the cam dowel rode around the gear and dinged up the edges of the dowel hole. Clean that up and hopefully it will fit together correctly.
Fun71 is offline
Old April 5th, 2020, 12:30 PM
  #42
jmcghee's Avatar
emery cloth is your friend
jmcghee is offline
Old April 5th, 2020, 02:09 PM
  #43
deadeyejedi's Avatar
.Try cleaning up the damaged part of the sprocket ,but only go in as far as necessary ,you dont want any play there.
Just reread this thread and see now that your old cam sprocket won't go on the pin either .so as stated use the emory cloth on the pin.go slow and careful you dont need to replace another cam
deadeyejedi is offline
Old April 5th, 2020, 03:30 PM
  #44
Sugar Bear's Avatar
Should of asked earlier...can you also post a picture of cam/dowel?
Sugar Bear is offline
Old April 5th, 2020, 04:34 PM
  #45
Supremecutty's Avatar
Thanks guys the dowel is good now i had to chamfer it (lightly).I would have put it back but live in an apartment(it's a daily driver and has covered parking) and it's raining too bad to go out and put it back together so hopefully tomorrow morning I'll put it all back and let everyone know how it went.😐😐 Then gotta get the distributor back on track lol i should've just let that be knowing i didn't touch it.
Supremecutty is offline
Old April 5th, 2020, 04:57 PM
  #46
jmcghee's Avatar
progess WAHOO!!!!
jmcghee is offline
Old April 5th, 2020, 05:03 PM
  #47
Sugar Bear's Avatar
Don't forget the fuel pump eccentric, you could install the fuel pump before the cover and shoot a picture of the gear lineup for when you second guess yourself later 😎...been there. Pour oil over the chain and gears before the cover install.
Good luck!!!
Old April 5th, 2020, 05:07 PM
  #48
Good luck!!!
thank you sugar bear will do buddy and thanks everyone else as well😁
Old April 7th, 2020, 03:59 PM
  #49
Alright guys i started up the car and man it feels good and sounds great. My distributor no longer has to be advanced all the way with the vacuum advance right by the firewall😁.
Old April 7th, 2020, 04:27 PM
  #50
Sugar Bear's Avatar
I am impressed with your persistence and ability to follow this through working with people you have never met to a successful outcome.
Good luck!!!
Old April 7th, 2020, 04:39 PM
  #51
Nice job!
Old April 7th, 2020, 05:18 PM
  #52
jmcghee's Avatar
Good job!
jmcghee is offline
Old April 7th, 2020, 05:54 PM
  #53
classicmuscle442's Avatar
Good to hear, it's not easy but very rewarding to get it running.
classicmuscle442 is offline
Old April 7th, 2020, 06:13 PM
  #54
Good news. You changed out the Edelbrock carb for the Q-Jet 7042250 carb, fixed the broken bolt on the carb (vacuum leak) & fixed the no start cam gear dizzy items.
Any pictures of the vehicle which houses this 68 Olds 350 you'd like to share?
Vintage Chief is offline
Old April 7th, 2020, 08:34 PM
  #55
lol is this john??? Hahahahahaha
Old April 8th, 2020, 03:56 AM
  #56
I was watching from the sidelines also. Congratulations!!!
Greg Rogers is offline
at3regency
July 12th, 2015 06:08 PM
nonhog
February 18th, 2012 07:02 PM
The Stickman
May 26th, 2010 07:37 PM
cisco88
January 26th, 2009 05:54 AM
olds87
May 24th, 2006 08:30 PM
Quick Reply: Changed timing chain now car won't start
