Good morning!
Old June 1st, 2014, 04:23 AM
Rick67OldsVert's Avatar
Good morning!
Hi,
This is my first post after joining the site. A big hello to all my fellow Olds owners! I just purchased a 1967 Cutlass Convertible. I am swapping the 330 for a 455 out of a 69 Delta 88 Royale. I am going to scrap the 69 but I wanted to know if anyone needed parts from it. It is complete except for motor and trans. I also need the pulleys and brackets for the 455. Any help would be appreciated!
Rick67OldsVert is offline
Old June 1st, 2014, 04:42 AM
Old School Olds
tru-blue 442's Avatar
Welcome to CO.
I think you will need the frame pads off the 69
if your going to use the 455 motor mounts.
tru-blue 442 is offline
Old June 1st, 2014, 04:45 AM
Engine swap
Thanks for the info. Both engines are ready to come out so I will check the frame pads.
Old June 1st, 2014, 04:46 AM
Engine swap
Will the 330 engine mounts fit on the 455?
Old June 1st, 2014, 05:26 AM
Getting There
Ranzan's Avatar
yes they will and welcome to the site
Ranzan is offline
Old June 1st, 2014, 06:24 AM
Welcome to the site, I don't believe you need to swap the pads.
oldcutlass is online now
Old June 1st, 2014, 06:38 AM
2blu442's Avatar
Welcome to the site! You can use either engine pads, but be sure you match the rubber motor mount with whichever steel pad you use. What part of the country/world are you in?
I'd encourage you to post parts from the 1969 Delta in the parts for sale section. Not a ton of demand for these items, but not much is being reproduced. So the guys restoring them have to look long and hard for parts. Pretty much anything that looks usable could be offered up. I know the speedometer cable that runs from the dash to the left front wheel is something that's often asked for. Fenders and bumpers if solid, any options, stainless or pot metal trim if good. Let me know if you need help exploring cost effective shipping options. John
2blu442 is offline
Old June 1st, 2014, 06:42 AM
2blu442's Avatar
One more thing. You can use the pulleys and brackets from the 330 or ones from any 350, 400, 403, 425, 455. Best to use a full set and not try to mix and match them. There are three different water pump lengths and you need to make sure you use the correct water pump for the pulley set. There are some combinations that look close, but if the belt is off by half its width it will wear badly and may be thrown.
John
2blu442 is offline
Old June 1st, 2014, 08:20 AM
Somebody hasn't been paying attention after all these years...
I'll suggest this thread as a refresher.
First, the 1965-70 full size cars DO NOT use "frame pads", so you'll be hard pressed to get them off the donor car. The 65-70 cars use motor mounts with a threaded stud that passes through a hole in the frame and is retained with a nut from the underside. None of that does any good on an A-body.
Once again, simply use the motor mounts that match your existing A-body frame mounts. On a 1967, that would be the Anchor 2261 mounts, which are also what the 330 uses (and the 67 442s used on the 400 BBO motors). People always make the motor mount issue much harder than it is.
joe_padavano is offline
Old June 1st, 2014, 09:15 AM
Thanks!
Old June 1st, 2014, 09:20 AM
Thanks to all for the info. This site is great!
Old June 1st, 2014, 02:02 PM
Old School Olds
Sorry Dad, you are right.
I forgot about those pesky
full bodied cars with the bolt
type mounts...C- for me.
Old February 8th, 2017, 06:43 AM
Olds Specialist LOL
JOHNNYOLDS442's Avatar
Morning Guy's
exciting day my 70 gets dropped off this afternoon
Hey Rick maybe throw it in the parts section, more guys might look there. GL
JOHNNYOLDS442 is offline
Old February 7th, 2019, 11:31 AM
Olds Fever
CRUZN 66's Avatar
I am confused... June 1, 2014, Feb. 8, 2017 and Today...
CRUZN 66 is offline
Old February 8th, 2019, 01:28 PM
btw
Smokin' BBQ Member
btw's Avatar
Just proves the point that on any given day, anyone can recyle anything
btw is offline
Old April 11th, 2019, 11:08 AM
Jouni, Since ya don't read the humor de jour thread
My wife said, "For my birthday, I wanta go see Jerry Springier live."
I got her sister pregnant and we're going to be on next Wednesday
Jamesbo is offline
Old May 4th, 2019, 01:26 PM
O'smobile
Orlando 1's Avatar
Talking
How was it with Jerry on Wednesday?
Orlando 1 is offline
Old August 27th, 2019, 06:29 AM
Some call me, Tim
Tim75's Avatar
G'morning ladies and germs. Happy cloudy Tuesday to you fine folks!
Tim75 is offline
cintr113
March 8th, 2013 07:04 AM
airlamb
July 26th, 2010 03:48 PM
gthmcty1
July 23rd, 2009 02:50 PM
gthmcty1
February 26th, 2009 06:21 PM
smyrna ranch
August 3rd, 2008 12:13 PM
Quick Reply: Good morning!
