Need 500 hp
Need 500 hp
Hey guys/ladies. I just bought me a 455 olds complete engine and I want to rebuild it to get at least 500 hp out of it. And with some good tq low and high, what will be the best combo for me? The engine is stock out of a 1972 cutlass with E heads and never bored and all stoke.
Your question reminded me of this article from Car Craft which I found interesting enough to remember it years later.
They were doing a 455 BOP shootout and this is the Olds build-up edition. While their test '72 455 Olds engine only made 470 hp @5200 with a Performer intake, read to the end, they believe it would have been higher with a better flowing manifold.
Torque? Not a problem.
http://www.hotrod.com/how-to/engine/...455ci-engines/
A good recipe for around 500 HP:
455 block bored .030, .040 or .060 over. (no more than what's needed for clean up)
Icon 886 pistons
Eagle 6.735" rods
stock crank ground .010/.010 or what's needed
Edelbrock heads, preferably with some mild porting but out of the box will work
A hydraulic cam (flat tappet or roller, take your pick) in the 230-240 @ .050 range
Edelbrock Torker intake
Holley 850 DP carb
long tube headers
and of course the appropriate rockers, push rods, oil pump & pan etc.
This will not be a cheap project to do it correctly. I would estimate you will have $6500-$8500 into it depending on your choice of parts and who you use for machine work. This is basically what's in my '65 with the exception of the heads which mine are iron with a good amount of porting. Mine hasn't been on the dyno but my time slips indicate around 485HP. Hope this helps.
Icon 886 pistons
Eagle 6.735" rods
Holley 850 DP carb
long tube headers
The bore will not cause you any overheating problems. You won't find any good off the shelf pistons in a STD. bore and it's best to start with a fresh surface.
Your E heads will need a lot of work to make 500 HP. Bigger valves, port work, new springs, retainers, guides etc. It can be done but will be cheaper in the long run to start with a set of Edelbrocks.
This is the Eagle kit for your block:
http://www.summitracing.com/parts/es...5060/overview/
You don't necessarily need a kit though. You can have your stock crank offset ground to 4.500" stroke and use 7" BBC connecting rods with either CP or Mahle pistons.
57 rocket
February 2nd, 2011 07:03 AM
68fastwilliams
April 30th, 2007 11:33 AM
Joe
October 9th, 2005 07:42 AM
