New cali guy with a 63 dynamic 88
Old June 6th, 2011, 07:32 PM
bagged63's Avatar
Unhappy New cali guy with a 63 dynamic 88
Picked up a dynamic 88 some months ago not running T the time. Rebuilt the car put a electric fuel pump and got it fired up. Bout a new stock fuel pump I'm going to put in soon. The bad. After getting it running i found that it over heats and that there is a crack in the timing chain cover. Also the right hea gasket is shot. Compression test checked out good. Think it has about 80000 miles. I have started my restorationonit but I've been reading on here Bout high compresson and low. I have no clue how to tell what it is. So I am goin to tell you what im doing to it beside motor work. Right now the car is in my buddys shop getting full air ride management system(accuair). It's laying full frame right now. I want to run side exhaust. I had bellflower exhaust on it and its so load and beastly. I am thinking flat blue with a heavy silver flake top. Full custom interior stereo. Rims I just want some clean looking 18s. I'm on my phone when I get a chance ill upload pictures
bagged63 is offline
Old June 6th, 2011, 07:33 PM
bagged63's Avatar
Sorry its a 4 door I have no clue what model
bagged63 is offline
Old June 6th, 2011, 09:09 PM
72 cutlass455's Avatar
Wow lots of work there post the vin number will be able to tell more about the car. Welcome to the forum
72 cutlass455 is offline
Old June 6th, 2011, 09:11 PM
bagged63's Avatar
632t11350 body type SD.
bagged63 is offline
Old June 7th, 2011, 05:16 AM
D. Yaros's Avatar
On the driver side head, below the valve cover and above the exhaust manifold in the center, you should find the engine number stamp. What is it? That will tell the type of engine.
D. Yaros is offline
Old June 7th, 2011, 10:16 AM
Past Administrator
Oldsguy's Avatar
Welcome to CO, sounds like some good plans for the car. Good luck, would love to see some pictures.
Oldsguy is offline
Old June 9th, 2011, 05:01 PM
bagged63's Avatar
Here are some pictures i have. Ill take some more this weekend when Im at the shop
bagged63 is offline
GTI_Guru
September 28th, 2011 04:08 PM
rene126
May 19th, 2011 04:04 PM
66ninetyeightls
May 7th, 2010 12:04 PM
truthautomatic
February 17th, 2010 01:01 PM
mugzilla
Vista Cruiser & Wagons
August 10th, 2008 06:14 PM
Quick Reply: New cali guy with a 63 dynamic 88
