New to the forum and to the olds family
Old September 25th, 2009, 06:57 AM
dsillies's Avatar
Just picked up a 67 Cutlass convertible (2 weeks ago). Still trying to figure out what I got. The former owner (had it for a couple months) said he thought it has a 455 from a 1973 cutlass 442. Any hint or direction (websites) on how I can figure out what I got (transmission especially because I need a flywheel cover) would be appreciated.
Seeing the pictures and reading the posting on this site will be very helpful. Thanks in advance.
dsillies is offline
Old September 25th, 2009, 07:09 AM
71 cutlass convertible
lshlsh2's Avatar
Welcome I sure some 67 owners will chime in quickly. A quick check on block size is to measure the intake. 12 inches across small block 14 inches big block. Should be a casting # on the front of the block behind the water pump I believe. Also look for a letter on the heads and post that. If it is a number it is a small block.
This is agreat site. You will have answers pretty quickly.
Larry
lshlsh2 is offline
Old September 25th, 2009, 09:07 AM
citcapp's Avatar
Talking Welcome to CO
If it is a 455 it most likley has a turbo 400 behind it. If its a turbo 400 it has an electric downshift, if its a turbo 350 it has a cable downshift.
citcapp is offline
Old September 25th, 2009, 04:52 PM
dsillies's Avatar
Thanks. Found the engine serial number 398021F. Is there a good site for tracking this?
I haven't checked the transmission downshift but will in the morning.
Thanks Pat & Larry
dsillies is offline
Old September 25th, 2009, 06:01 PM
Nilsson's Avatar
I believe it should be a 396021F, regardless F indicates a 455 70-72.
And welcome.
Nilsson is offline
Old September 26th, 2009, 09:25 AM
dsillies's Avatar
you are correct. thanks
dsillies is offline
Old September 26th, 2009, 09:43 AM
Past Administrator
Oldsguy's Avatar
Welcome to CO.
Oldsguy is offline
72'CutlassS350R
December 29th, 2014 12:23 PM
oldspackrat
November 9th, 2011 07:57 AM
Firebrand
July 21st, 2011 01:26 PM
Alienbaby17
September 30th, 2010 01:38 PM
easytobedead
December 11th, 2008 06:16 PM
Quick Reply: New to the forum and to the olds family
