New owner 1966 Oldsmobile Delta 88 Holiday Coupe
Hi, I'm not a brand new member, I've owned a 1966 Oldsmobile Dynamic 88 4 door Celebrity sedan for 15 years and last year buy the version Delta 88 Holiday Coupe, 425cui HC 310hp 2bll engine (TH400, A/C, deluxe steering wheel, el. windows, el. six way seats and a white vinyl roof .. it was a C08 option, but I did not find it in the dealer books and price lists for the Delta 88 version (for the 1966 model, I found it as an extra option only for the 98 and Cutlass Supreme) but it was clearly available, for the Delta 88 version I saw it live only here, but on the Internet about 4 cars were always in black (only white and black were on offer), I think vinyl roofs were popular already at the end of the 60s. Actual waitting parts from fucick.com and I'm waiting to change the brake cylinder.
Sorry my english not perfect i am from Europe :-)
Very nice car, enjoy it and drive it many miles!
If it is original, that TH400 is a switch pitch/variable vane torque converter.
Keep the old brake master cylinder, it is probably original and can be rebuilt.
Good luck!!!
Good luck!!!
I think the vinyl top was added later, and that was actually pretty common in US in 60s and 70s. A good way to tell is to remove the top edge molding and look at the trim clip studs. If they look like Phillips head screws, odds are good the top is an aftermarket installation. If the stud heads are flat probably a factory installation.
Paint code DD is Lucerne Mist upper and lower body color. Even if the car had come with a painted roof, the upper body color code would have been different.
Handsome car whether it came with VT or not.
Have you figured out how to correct the choke linkage yet? Looks like at some point in time that carb was disassembled down to removing the choke plate and shaft and it was reassembled wrong.
Bad instalation choke line TANG ( actual in car )
This is correct "tang" .. my second 2bll carburator
Hmm just a guess, the first picture- the black stat cover/spring assist is turned way to far to the right-(clockwise)-see where it says lean-rich, that should be to the left of the top screw where the groves ( markers for choke adjustment) in the housing. So that tells me that there's a chance that the spring inside the choke cover is not connected to the choke plate inside the choke. In other words if you loosen the 3 screws just a little so you can turn the black cover you should be able to feel some spring tension. Just a thought, I'm rebuilding a carb as we speak.
As Glenn correctly points out, RPO C08 was not available on any model in the Eighty Eight line in the 1966 model year, and the cowl tag clearly shows that this car came from the factory painted Lucerne Mist upper and lower body color. I'm curious how you fitted the Cutlass SuperStock wheels. From the factory the D88 had a 5 x 5" bolt pattern. The SSII/III wheels are 5 x 4.75" bolt pattern. Are you using adapters?
That's what I thought, but the C08 extra option is listed as possible for 1966 models according to the original "1966 Oldsmobile Dealer book" ? I have nothing to compare it to, but it looks so nice on the car that I think it is a factory installation. When the time comes, I'll try to remove the rear seat if I can't find a "build sheet"
yes, there are adapters for changing the spacing, I like these wheels for the Delta 88 (I have the original steel ones with the original covers for the car - 8 pieces in total)
I started looking for the buildsheet today, but no luck. In the usual places (the inside of the front fenders, the underside of the seats) there is still nothing under the carpet, but I haven't removed it yet.
According to the BC code, the car was manufactured at the Southgate CA assembly plant ?
Code 04E is the 4th week of May 1966?
I replaced both front hood and rear trunk light bulbs and they are now shining :-) Otherwise, as far as I understand, the car has additional equipment:
A31 electric windows
A39 seat belts
A42 6 way electric seats
A91 trunk lid latch
C60 air conditioner four season
D31 mirror glareproof rearview
J50 power brakes
M40 transmission TH400
N40 power steering
P29 tires 8.55x14 ( option C60 )
U35 electric clock
U63 Radio deluxe
Y60 lamps and mirrors
Y76 engine cooling equipment ( option C60 )
Original brochures :-)
A39 seat belts
A91 trunk lid latch
J50 power brakes
N40 power steering
U35 electric clock
U63 Radio deluxe
Beautiful car. Previous owner(s) really took care of her. When you have time take some pics of the interior. The only option you need to add is a gun rack in the rear window for a Kalashnikov 🤣
OK, clearly it was a mid-year change to add the availability of C08 across the model lines. Here's a build sheet from a 1966 442 from the Fremont plant that clearly shows C08. Apologies for the bad info earlier, and thanks for making us research this more. Just note that paint code on the cowl tag on your car proves that it came from the factory without a vinyl top.
I can't decide whether the vinyl roof is original from the factory or added later, according to the information from the sales brochure of the time, order it for the Delta 88 1966 model under the code C08, but it looks like the roof under it is painted in the color of the car (code DD), I am attaching today's photos under the leaves.
the interior is super warm without a fault (only someone additionally installed a cycle wiper)
There's nothing to decide. The "D D" paint code on your car's cowl tag PROVES that it came from the factory with the roof painted. Had this been a factory vinyl top car, the second character of the paint code would have been a digit, not a letter. And per the color booklet you posted, the only available vinyl top colors for 1966 were black (which would have been paint code "D 2" on your cowl tag) or beige (which would have been paint code "D 6"). White was not an option.
I like the vinyl top on this car. I’m less learned than all of you, but I’d put my money on this being an aftermarket addition.
The rivets holding the plastic trim retainers don’t look factory. I believe Olds would have used welded in studs to hold the trim retainers in ‘66. Also, most all the vinyl they used in ‘66, they called “Morroceen” or similar marketing name. That grain is more commonly known as Madrid grain in the upholstery world. Finally that center retainer mating the 2 pieces of trim wouldn’t have been done by GM this way - they would have made one side or the other the keeper and have the opposite side slip into it, like you see above.
If ever you want to replace the vinyl, I’d go for Madrid White or Madrid Off white per your preference. But for now, drive & enjoy that great car!
Chris
Chris
I know there is an not complete list of Oldsmobile dealers codes:
My Oldsmobile Delta 88 1966 was sold here: Selling dealer code no. 23-520
Apparently in California, can anyone find out the name of the dealership by the code?
ere is my 66 LS December build trim tag. Yes it came with a whitish vinyl top, was amazed to see that under the front and back glass moldings thick metal staples thru the channel holding the top in place.
"6" was beige, not exactly white. White would have been a "1"
I had the original steel disc sandblasted and painted. The 1966 Delta 88 model had standard tires in size 8.25x14 (version without air conditioning) or 8.55x14 (version with air conditioning - my car has AC) Is my conversion to radial tire 8.55x14 = 225/75/R14 correct?
Thanks guys
Thanks guys
Thanks guys
Thanks guys
Thanks guys
Thanks guys
can I buy new Kontio tires in size 225/75/R14 with a wide 2¾ white stripe, or can I buy American Classic in size 215/75/R14 with a narrow stripe (the wider 225 is not made)
I don't know if a wide stripe is suitable for 2HT .. in the mid-60s there were rather narrow stripes.
#31
#33
Not quite the same, but your options are limited. The 8.55x14 OEM tires had an 8.50" section width and a 27.94" outside diameter. 225/75-14 tires would have an 8.86" section width and a 27.29" outside diameter. Short of buying repro 8.55x14 bias ply tires, that's about the best you can do.
Please explain why the full size models of the year 1966 Oldsmobile DYNAMIC 88, DELTA 88, STARFIRE use 5x5 spacing and the only JETSTAR 88 uses 4.75x5? The weight of the full size models will be quite similar, this is due to the smaller and less powerful 330cui engine vs. 425cui?
#34
Joe,
#35
The J88 was the low-cost loss leader of the B-body line. It used the smaller and lighter 330 and Jetaway trans vs. the heavier 425 and TH400. As part of this Olds used the smaller A-body 9.5" drum brakes and the lighter 8.2" A-body rear axle. J88s were also relatively low content, so also less total weight. Note that the same year Impalas used the smaller brakes and bolt pattern as well.
#36
Thanks for the info, so the reason was lower production costs. On my 1966 DELTA 88, the previous owner used adapters from 5x5 to 4.75x5 on the wheels due to Cutlass SS II / SSIII wheels . The question is safety and whether the change in spacing can affect other parameters (shock absorbers, bearings)
#37
#38
The 15x7 steel wheels used on the 1977-1990 GM B-body wagons (Custom Cruiser, Caprice wagon, etc) are 5 x 5" and will clear any future disc brake upgrades if you are so inclined. Not sure how easy it is to find these in Europe.
#39
