Newbie
Old May 3rd, 2009, 06:52 PM
broman1960's Avatar
Newbie
Hi folks, I have a 1982 cutlass supreme that originally came with a v6, I swapped to the 307 because the v6 died after 212k miles. I developed a oil leak from the oil pan, I know its the gasket, I was told that it would a hefty labor charge to fix it, so my mechanic a sealer on it called Locktight? Has anyone ever heard of this?
broman1960 is offline
Old May 4th, 2009, 07:19 AM
citcapp's Avatar
Never heard of fixing a gasket leak with a sealer. Best bet replace the gasket. If you have a garage or even a driveway not to hard of a project to take on yourself
citcapp is offline
Old May 4th, 2009, 08:16 AM
Past Administrator
Oldsguy's Avatar
Unless the mechanic was repairing one or more loose bolts by applying loctite to their threads; even then, it would require quite a few (definitely more than one or two) loose ones to allow the pan to leak. Loctite is a branded name of thread sealer products that come in different colors (red, blue) which have different holding characteristics and can be used in engine assembly.
Oldsguy is offline
usertroy
December 13th, 2012 08:19 PM
Scottem
May 29th, 2012 11:24 AM
marty
Site Help
November 30th, 2009 06:08 PM
Quick Reply: Newbie
