1955 olds 98 Starter problem ..help please
Old August 19th, 2013, 12:16 PM
oldsladyliz's Avatar
Hi I went to take my car out to the show Sunday and suddenly the starter just made a clicking noise near dash..did not start .. what should i do to check this out... first.. i so far cleaned the cables, made sure battery was fully charged etc.. so need some help to check this out.. thanks Liz
oldsladyliz is offline
Old August 19th, 2013, 12:42 PM
If you have a charged battery and you've already cleaned and checked battery cables and terminals, then it's time to move to the starter solenoid. First make sure the wire terminal connections are good and that you have voltage at the S terminal when the key is turned to the start position. If you have voltage there then I would assume a bad solenoid, or brushes.
oldcutlass is offline
Old August 19th, 2013, 01:07 PM
thanks i will do this.. and get back to you.. i appreciate it..
Old August 19th, 2013, 02:15 PM
i think it is the solenoid..now to find one and put it in......... thanks you were right on..
Old August 19th, 2013, 03:24 PM
oldsmoguy's Avatar
Rock Auto has the solenoid and the rubber boot
oldsmoguy is offline
Old August 19th, 2013, 03:55 PM
Junkman's Avatar
I have found that what might look like a bad solenoid, sometimes is bad bushings in the starter nose cone or the end plate. To check this, while someone holds the key to the start position, gently wrap on the bottom of the starter with a hammer. If the starter starts spinning, then it needs to come out for a rebuild. The reason that this works, is that the rapping of the hammer, makes the armature jump, and then it can spin freely. If the bushings are bad, the fields will pull the armature toward them, and it will not be able to spin.
Junkman is offline
Old August 19th, 2013, 04:03 PM
m371961's Avatar
The above hammer trick can also be a solenoid. The hammer jars the corroded contacts and then they work. You can dissasemble the solenoid and flip the stud contact and clean the disc. They actually used to sell contact kits, but personally, I change out the solenoid.
m371961 is offline
Old August 20th, 2013, 05:16 AM
yes i think this is a must do... i appreciate all the help..thanks everyone..
thanks i will check them out..
Old August 20th, 2013, 05:28 AM
stellar's Avatar
You may want to inspect the solenoid when you remove it. If it worn out, chances are good the bushings and brushes in the starter are also near retirement age. If the starter is off the car it would be good to open it and do a visiual inspection of the starter.
stellar is offline
Old August 20th, 2013, 09:53 AM
yes you are right.. i think the starter will be replaced at the same time if it looks even the smallest amount worn.. we don't want this to happen on the road on the way to shows.. thank goodness Lucille decided to do this in our own garage.. lol....... thanks
Old August 20th, 2013, 10:09 AM
Proud Viet Nam Veteran
redoldsman's Avatar
You probably only want to pull the starter one time also. That is just a dirty job that is not fun. Good luck.
redoldsman is online now
Old August 20th, 2013, 11:54 AM
Let us know how you turn out.
Old August 20th, 2013, 02:32 PM
They were tested again and then the starter and selonoid were taken out..they are on the way to repair..and new selonoid ... i had local man with body shop get under the car and take them out.. car was in the garage when this happened.... i have no lift.. so lifted with jacks and enough room for him to get under.. also he had all the right tools.. he will bring the new ones back and install in a week or two.. meanwhile we will take the 38 olds to the show.. thanks everyone for imput.. i will let you know how she rides when everything is done.. feel better though that this won't happen again for a long time.. she never let us down before so i quess she deserves some time off... thanks !!
electra483
Wheels and Tires
18
July 8th, 2014 02:25 PM
sanemb
October 10th, 2012 03:34 AM
rket56
July 1st, 2012 04:54 PM
morrowjm4154
May 30th, 2010 08:32 PM
morrowjm4154
May 29th, 2010 02:12 PM
Quick Reply: 1955 olds 98 Starter problem ..help please
