1993 Olds 98
Old April 15th, 2021, 12:27 AM
TheRealMcCoy's Avatar
1993 Olds 98
Does anyone know the story on this top?
Was it rare?
1993 Oldsmobile 98
1993 Oldsmobile 98
TheRealMcCoy is offline
Old April 15th, 2021, 05:27 AM
That is a dealer installed top or aftermarket. As far as I know, the 91-96 98s weren't offered with a vinyl top from Oldsmobile.
Make sure the cooling system is in good repair on your 98. The 3.8l v6s used DexCool coolant and it has a tendency to gel and clog the radiator and water jacket. Unfortunately you can't change to traditional green coolant unless you rebuild the engine and swap the radiator/heater core.
Olds64 is online now
Old April 16th, 2021, 04:58 AM
That is a beautiful Olds!
One of our other members; Allan R, drove a late model C body 98 in the past. He speaks highly of them. I drive my 96 98 every day 70+ mile to and from work. I generally get 21+ mpg.
Does your Olds have leather or the supercharged engine? I drove to Houston, TX to buy my 98. Let us know if you have questions.
Old April 16th, 2021, 06:54 AM
Proud Viet Nam Veteran
redoldsman's Avatar
Those tops were often referred to as Carriage Tops back in the day. Senior Citizens loved them and they often were accompanied by gold trim. I referred to them as the Senior Citizen Package. They usually had a fiberglass shell that was installed and the top was installed over that. They were not cheap and I think cost something like $1,500 at that time.
redoldsman is offline
Old April 16th, 2021, 08:09 PM
Thanks for the feedback. Great information.
The interior is going to clean up nicely. It is leather.
Old April 17th, 2021, 10:02 AM
gkhashem's Avatar
I do not think the 1993 had Dex-Cool my 1992 does not. I think that started in 1995 or 1996.
gkhashem is offline
Old April 17th, 2021, 03:43 PM
If his 3.8l doesn't have DexCool that's excellent!
Old April 17th, 2021, 04:20 PM
gkhashem's Avatar
Introduced by GM in 1995.
https://www.hemmings.com/stories/art...like-a-rainbow
Really Dex-cool is not the issue its the intake manifold gaskets. Change them and you are all set. Spend the $800 or so and do it. If the car is good it will rust first before the engine dies.
gkhashem is offline
Old April 18th, 2021, 04:37 PM
blakes7's Avatar
I've replaced the dex cool with green Prestone in two different 2007 GM cars and had no problems for several years now.
blakes7 is offline
Old April 22nd, 2021, 04:49 PM
1993 Oldsmobile 98 Regency Special Edition. Leather interior, rear window defroster, power everything.
Old April 23rd, 2021, 05:51 AM
I like those wheels better with the paint/powder coating in the center and the polished trim ring vs. the satin aluminum wheels available on the 91-96 98s. It matches the padded vinyl top.
junker garage
April 20th, 2019 05:52 AM
wfrs2007
Ninety-Eight
July 26th, 2007 02:35 PM
Quick Reply: 1993 Olds 98
