Fuel gauge stuck
Old December 7th, 2023, 05:25 AM
Thatch's Avatar
Fuel gauge stuck
I have gotten some excellent help and advice so far from this forum it has been great!
I have a fuel gauge on my '69 98 that is stuck somewhere in the middle. I have not done any investigating on this issue and wonder if anyone has a starting point for me.
The car runs beautifully, odometer and speedo work, just trying to sort out some details .
I imagine the float is stuck in the tank but before I go removing anything I figured I'd see if anyone has a solution.
Thatch is offline
Old December 7th, 2023, 05:29 AM
Just to be clear regarding being "stuck". Do you mean the needle "remains" in the middle position both with the car in the ON running position AND when the car IGN is turned to the OFF position?
Vintage Chief is offline
Old December 7th, 2023, 05:32 AM
Thatch's Avatar
Yes. Doesn't move regardless of whether the the ignition is on, or if the car is running
Thatch is offline
Old December 7th, 2023, 05:35 AM
Lots of threads (using the Search feature) regarding fuel gauge issues. I'll point you to one such thread for a quick review. Try this to see "if" the needle moves at all. Chance it's mechanical (in the gauge itself) or electrical.
https://classicoldsmobile.com/forums...t-wack-176067/
Old December 7th, 2023, 06:00 AM
Here is another well written thread you might read to gain a better understanding of troubleshooting your issue. Obviously, you should be looking to see "if" the gauge will move at all.
https://classicoldsmobile.com/forums...-right-146663/
Old December 8th, 2023, 07:37 PM
Thatch's Avatar
I ordered the CSM. Has not arrived yet.
the gauge is stuck at about 1/4 full. I noticed a tiny amount of movement when I turned the key but very very little.
I found a ground wire just above and in front of the tank, cleaned it but still no improvement. I can't seem to locate the power wire from the tank. I guess the manual will give some insight but wondering where the power wire for the sender is located
Thatch is offline
Old December 8th, 2023, 08:18 PM
I looked at the 1969 A-Body wiring diagram (located in your CSM when it arrives), it is a TAN 20GA wire. What I'm not sure of is the routing of that wire for a 1969 98 - sorry. Later models (at least 1971) the TAN wire came up from the top of the back of the fuel tank, through a rubber grommet in the trunk floor on the RH-side of the trunk latch and plugged into the Fisher Body wiring harness.
1969 B-Body & C-Body wiring diagrams >>> 1969 Wiring Diagrams
Old December 8th, 2023, 08:26 PM
Old December 8th, 2023, 08:35 PM
Two diagrams. One from the 1969 PIM (Product Information Manual), the other from the 1971 PIM. Again, I'm not clear on the exact routing. It appears different between 1969 & 1971; although, there were also improvements in the actual wiring diagrams themselves so I'm not clear (again) where the actual TAN 20GA wire emanates from the fuel tank on the 1969 98.
1969 PIM Fuel Gauge Wire Lead
1971 PIM Fuel Gauge Wire Lead
Old December 13th, 2023, 05:33 AM
Thatch's Avatar
Haven't had much time this week with the 98 but I was able to determine the gauge is working by grounding out the gauge wire in the trunk.
Im assuming since the gauge goes back to about 1/4 full when plugged and stays there, that there is a problem with the float or sender in the tank.
Thatch is offline
Old December 13th, 2023, 06:12 AM
Yes, float or sender.
If you performed the tests as indicated in the URL link (thread) I provided above https://classicoldsmobile.com/forums...-right-146663/; and, the gauge needle can swing/move to E and then to F, you've validated gauge is working & gauge is not the issue.
In the simplest of terms,
Troubleshoot disconnecting the sending unit wire in the trunk near where it goes through the grommet and ground the gauge end. If the needle goes to E, the issue is towards the sending unit. If nothing happens, the issue is towards the gauge.
synoptic12
September 13th, 2022 04:15 PM
smparr
November 6th, 2021 07:53 PM
71Cutlass "S"
Tech Editor's Desk
38
April 3rd, 2020 04:39 PM
Darin Matera
November 12th, 2014 07:04 PM
ozzyolds
August 13th, 2008 11:11 AM
Quick Reply: Fuel gauge stuck
