Stock gear ratio in 1964 98
Old June 14th, 2022, 08:10 PM
drjaredshelton's Avatar
Does anyone know off hand the stock gear ratio in a 1964 98 4dr hardtop? Or if it’s stamped on the housing somewhere or in the vin code. Thanks for the help
drjaredshelton is offline
Old June 15th, 2022, 04:38 AM
Oldsfan's Avatar
Nothing in the vin. Should be a code stamped in the carrier. Don't know what the codes are for '64. I'm guessing it's a 3.23 or a 3.08. Starfires used 3.42s.
Oldsfan is offline
Old June 15th, 2022, 10:52 PM
Phantom Phixer
Charlie Jones's Avatar
The diff carrier is stamped with a number on the outside flange where it bolts to the axle housing .
It will be in about the 7 o clock position as you look at it from the front.
The axle codes are listed in the 1964 Oldsmobile Shop Manual.
The letter "L" stamped next to the code number designates a limited slip (posi) differential.
Charlie Jones is offline
Old June 16th, 2022, 05:34 AM
Perfect. Thanks Charlie. I’ll climb under there and look.
Old June 16th, 2022, 02:48 PM
Okay, so I have a 9. (3.23)
here is the chart for anyone that might need it in the future.
Old June 16th, 2022, 09:39 PM
v8al's Avatar
v8al is offline
Old June 17th, 2022, 08:00 AM
cfair's Avatar
3.23 is my favorite ratio for these old cars. Obviously 3.08 gets better mileage, but 3.23 is more fun. Recommend against 2.93 if you come across it, best mileage, but not so hot off the line.
And we’re not keeping these cars for their legendary fuel economy, so why not have some fun?
cfair is offline
Old June 17th, 2022, 08:05 AM
Right, although I wouldn’t mind finding the 3.90L
Old June 17th, 2022, 05:11 PM
Phantom Phixer
It would leave two black marks on the road........
Old June 17th, 2022, 09:07 PM
:d
twiggy
June 22nd, 2022 05:44 PM
shiftbyear
September 6th, 2021 05:14 PM
Jandk
Drivetrain/Differentials
September 15th, 2015 12:40 PM
dadedave
May 28th, 2012 08:45 PM
65olds98
October 15th, 2008 11:01 AM
Quick Reply: Stock gear ratio in 1964 98
