Trim tag Decode?
Old September 20th, 2009, 10:37 AM
Land Yacht Club
Crow62's Avatar
Trim tag Decode?
Can anyone decode these numbers for me?
Left front cowl
12B Lansing
Style 62 - 3839
Body LA 4372
Trim 375
Paint L-C
ACC-493-555-622
Crow62 is offline
Old September 29th, 2009, 01:07 PM
jaunty75's Avatar
The 12B means assembled the second week of December. Given that your car is a '62, this would be December 1961.
The 3839 is, I believe, the series and body style (it's the same as the first four digits of the VIN, I think).
From this we can tell that you have a Ninety-Eight Holiday Sports Sedan (4-door hardtop?)
Trim 375 means a red pattern cloth (called Moroceen) with red carpet and white headliner.
Paint L-C means is, I believe, "garnet mist" (kind of a dark red) main paint color (the L) with "provincial white" trim (the C). Does your car possibly have a primarily red body with a streak of white down each side?
BODY LA 4372 is the body sequence number at the Lansing assembly plant.
As far as the accessory codes, 493 = electric antenna and "bi-phonic" speaker system. 555 = white sidewall tires and air conditioning. 622 = electric 6-way seat.
Since you apparently have a '62 Olds, you REALLY should check this site out (it's where I got all the above info!):
http://home.comcast.net/~oldsfan/MySite/62oldspage.html
jaunty75 is offline
Old September 30th, 2009, 05:32 AM
Land Yacht Club
Crow62's Avatar
Great help, thanks.
Crow62 is offline
Old September 30th, 2009, 05:36 AM
jaunty75's Avatar
Glad to help. I am curious. Does your car have the paint scheme I mentioned, or did I not interpret the code correctly?
jaunty75 is offline
Old September 30th, 2009, 05:48 AM
Land Yacht Club
Crow62's Avatar
It looks like the way you describe it, except for the white stripe.
Crow62 is offline
Old September 30th, 2009, 06:08 AM
jaunty75's Avatar
Interesting. I had the impression it might have looked like this.
jaunty75 is offline
Old September 30th, 2009, 06:18 AM
Land Yacht Club
Crow62's Avatar
I wish it was that clean
Crow62 is offline
knoggin
April 17th, 2014 01:48 PM
compusign1967
October 26th, 2011 02:00 PM
bobb
September 29th, 2010 07:03 PM
Boh2k
September 27th, 2010 07:16 AM
drtdobber
February 14th, 2007 01:16 PM
Quick Reply: Trim tag Decode?
