Non-Olds Engines For discussion on non-Oldsmobile engines. All forum rules apply.
1956 Olds 88 Holiday Coupe LS3 Swap
Old October 19th, 2020, 12:04 PM
Obi70's Avatar
Hi , a lot of work has been done since I bought the car a couple months ago .
Front clip was cut and replaced by a Fatmanfab clip.
Big block and trans are gone . LS3 is being build as we speak. 550 horses at the rear wheels. Yes it’s gonna be a rocket.
Car interior is gutted to replace the lousy done wiring harness .
New wheels arrived from Detroit Steel .
I better let the pics talk .
Thanks ,
Oliver
Her name is Eloise !
Obi70 is offline
Old October 19th, 2020, 02:06 PM
Loaded68W34's Avatar
That is going to be awesome!
Loaded68W34 is offline
Old October 19th, 2020, 02:48 PM
oldsmoboogie's Avatar
I was thinking of those wheels for my 56 also. What size tires are you going with?
oldsmoboogie is offline
Old October 19th, 2020, 08:03 PM
jozw30's Avatar
Not sure if it will be a ton of help but you can search for my 55 88 build thread in the non-Olds motor section. Fatman stub, ls2, 4l65E, lots of custom stuff.
One thing for sure, check the Fatman sway bar. I put mine away until I got to final assembly and then discovered that it wasn’t even close to bolting up. They didn’t have an answer but gave me some money back (after like 5 years....good company to work with) and I had to have a custom bar made ($).
Good luck, cool car!
Joe
jozw30 is offline
Old November 15th, 2020, 03:28 PM
Obi70's Avatar
Update :
Project hit a roadblock FatmanFab sent the wrong upper control arms . New ones arrived yesterday .
Car is no nearly complete insulated and the air ride components arrived.
Brake pedal relocation kit is installed
Engine should be done soon . Transmission comes down to 2 choices 700R4 or 4L80E . Not sure yet.
Will keep you guys updated.
Brake Conversion Kit
Brake Pedal Mount
Airbox replacement plate
Upper control arms with wrong radius
The Beast
Noico Insulation
Rack for Airride components
Obi70 is offline
Old November 15th, 2020, 07:37 PM
Looking good, nice work.
oldcutlass is offline
Old December 4th, 2020, 10:33 AM
Obi70's Avatar
Update:
The new upper control arms finally fit . Willwoods and R&P are installed .
Wheels arrived ( Conti’s 245/40/20 ) and they are smaller than the old ballons .
Fabricated panels for the RH airbox and the forward body mounts.
Engine is in its final stage and looks just plain sexy with the pulley system .
Going with a 4L80E due to high horsepower and torque .
Keep you guys updated ,
Olli
Obi70 is offline
Old December 4th, 2020, 10:43 AM
OHHH YEAHHH! Thanks for sharing. Can't wait to see more pics.
Olds64 is online now
Old December 4th, 2020, 11:07 AM
jozw30's Avatar
Looking good!
jozw30 is offline
Old January 18th, 2021, 08:34 PM
Obi70's Avatar
Happy New Year!
Firewall parts came back from powder coating .
New vintage air unit found it place under dash
I even found my car in small and got a great neon for my birthday
Nice and slick !
Little custom touch .
Minnie Me
Obi70 is offline
Old January 18th, 2021, 09:08 PM
I love it. Build it like you love it. Awesome.
This picture so tells me that we are distant brothers. That and the Muscle Machine 👍
no1oldsfan is offline
Old January 20th, 2021, 08:03 AM
Obi70's Avatar
Thanks !
Using the lockdown to build my kinda Olds ! 🤘🤘
Obi70 is offline
Old April 1st, 2021, 06:43 PM
ArTrvlr's Avatar
I am kinda new here as well and just found your thread. I am restomodding a 58 88 so all you are doing is interesting and helpful for ideas. I had thought about the body mount covers and seeing yours has convinced me to make some.
What is your opinions on the firewall brake conversion kit? Is it well made, fits like it should, etc? Is that from Battle Born Brakes?
Your work looks great, any updates?
ArTrvlr is offline
Old April 1st, 2021, 08:19 PM
Obi70's Avatar
Smile
Hi . It’s the battle born brake kit. It’s well made , ships fast and the guys are very helpful . I’ve ordered it on EBay .
I’ve only added some structural braces to the pedal bracket ( That’s the German engineer speaking ) Just in case the 650 horses need a emergency stop.
Waiting for my rear end housing to be delivered , so I can start with the 4 link . Gonna be a tight fit with the air shocks , gas tank and the exhaust .
Here are some new pics .
Someone needs a new project ? 😉
Wheels will have new clearance issues , even in low park mode.
Obi70 is offline
Old April 2nd, 2021, 06:15 AM
ArTrvlr's Avatar
Thanks for the update and brake kit info. I thought I saw a part in your installation that I don't see in the Battle Born pics. Looks like a good idea that will add support to the pedal bracket. I tend to over engineer also, but that's because I'm not an engineer.
Where is the electric wiper motor from? The only one I have found is Newport Engineering. And (sorry for so many questions) what is the item covering the wiper motor in the last pic? Also, does the firewall plate in the center enclose the wiper motor?
Thanks for your help and ideas.
ArTrvlr is offline
Old April 2nd, 2021, 08:53 AM
Obi70's Avatar
The wiper motor is from Newport engineering.
‘It’s sticking out , so I will cover it with a German WW2 gas mask canister. That’s the item on the picture.
Not a theoretical engineer here. I learned my stuff on the go wrenching.
Obi70 is offline
Old February 23rd, 2022, 01:47 PM
61Bat's Avatar
Any updates Obi70? Getting ready to do the same to my 61 88 so I appreciate the pictures!
61Bat is offline
Old February 23rd, 2022, 05:17 PM
Tedd Thompson's Avatar
I don't know if you are going stock with the Batwing air cleaner, but that Krout canister will most likely rub on the Batwing, there is very little room between it and the wiper motor, just a thought.. Tedd
Tedd Thompson is offline
Old March 3rd, 2022, 07:00 AM
Obi70's Avatar
Hi Ted ,
I’m using an LS3 engine , so no air cleaner .
Obi70 is offline
Old March 3rd, 2022, 07:07 AM
Obi70's Avatar
Unfortunately is my project on the back burner .
Work got really busy and I’m traveling a lot .
Engine sits on the floor next to the rear end .
Obi70 is offline
Old March 4th, 2022, 04:02 PM
Sorry to hear it is slow going but it looks great. Trans looks like a pullout. Is the motor a pullout or a new crate motor? The motor looks incredibly clean if it is a pullout. What serp syetem is that?
Old March 5th, 2022, 03:49 AM
I like it- A LOT... Don't trash any original stuff, I'll bet some of the guys would love to buy it.
Greg Rogers is offline
Old August 15th, 2022, 06:50 PM
Obi70's Avatar
They are both pull outs and overhauled .
its a C1 Pulley System
Obi70 is offline
Old August 15th, 2022, 07:07 PM
Obi70's Avatar
Update :
Will start a new job in the fatherland and can’t continue the project .
Been locking around for a shop to finish her , but that’s nearly impossible ( nobody wants to work anymore , all shops are logged up - lack of staff)
Also trying to figure out if it’s even possible to register the car in Germany ( stricter rules )
Which leads me to maybe selling the whole project .
Still a big debate inside my head 🤪
Anyway starting to get rid of a lot of old spares and leftovers .
Working on pictures for the for sale section
Obi70 is offline
Old August 16th, 2022, 04:15 AM
Past Administrator
Oldsguy's Avatar
So sorry to hear the news since it means you need to change directions with your project even though it means a new chapter in you professional life. Good luck in whichever direction you decide to go. I thought I might ask you how the NOICO was to install, easy, difficult, sticky, rigid?
Oldsguy is offline
Old August 16th, 2022, 05:06 AM
Hope you find a solution since you'll be returning to Germany. Is vehicle registration in Germany federal or done by state? Maybe one of the states has more lenient rules?
Old August 16th, 2022, 06:40 AM
Obi70's Avatar
Noico is really easy to work with.
Lay it in the sun or heat it a little up with a heat gun .
Thanks for your kind words.
Obi70 is offline
Old August 16th, 2022, 06:42 AM
Obi70's Avatar
It’s by state but they are pretty much on the same level.
They want for everything a certificate and this is very costly .
Obi70 is offline
oldstata
November 30th, 2020 05:25 PM
Mikekuj
January 24th, 2020 07:19 PM
Kada
July 19th, 2019 06:03 AM
clean cut creations
November 6th, 2012 10:17 AM
BEAR
28
February 27th, 2010 04:39 PM
Quick Reply: 1956 Olds 88 Holiday Coupe LS3 Swap
