Non-Olds Engines For discussion on non-Oldsmobile engines. All forum rules apply.
1973 Omega Restoration with Pontiac ohc6 sprint
Old October 11th, 2019, 05:36 PM
  #41
JohnnyBs68S's Avatar
This is cool. Like Frisbee_K9, my dad purchased an economy car in '74 because of that gas crisis. His choice was a 4-door Pontiac Ventura with the 250-L6, AT, PS, PB, AM radio and rubber flooring. The "Blue Jewel" was her name. Wheels were the moonie dog-dishes on body-color steel 14" rims. It was so stripped down he had to special order it. Both my younger twin sisters and I learned to drive in that car (mom's gently used '68 Cutlass -- in my sig -- that he purchased from his neighbor 6 months after this Ventura arrived was off limits!), and in the ensuing years we rode that car hard and put 'er away wet. I remember racing a work buddy in his 2-door '74 Ventura w/ 250-L6 and 3-on-the-tree, also on moonies w/ body color rims (I won due to the 3-on-tree disadvantage he had), and doing doughnuts in the church parking lot packed with friends with that car. Dad even bolted a bumper hitch to the Blue Jewel and used it to tow his ~16' tri-hull boat.
I've always hae a soft spot for these X-bodies, Nova, Ventura, Omega, Apollo. Sharing the front suspension w/ the F-bodies made them handle quite decently. I love where you are heading with this project, and being in Austria is the cherry on top. Will be following this thread for sure.
JohnnyBs68S is online now
Old October 18th, 2019, 12:33 PM
  #42
Olds Omega
exotec's Avatar
engine and trans are out
exotec is offline
Old October 21st, 2019, 12:12 PM
  #43
Olds Omega
exotec's Avatar
frame and A-arms are almost ready for blasting and powder coating (semi-gloss black). ball joints and bushings will be removed before of course.
the welds on the frame aren't that great! will be reworked and flattened a bit.
exotec is offline
Old October 24th, 2019, 09:55 AM
  #44
Olds Omega
exotec's Avatar
it will be awesome!
but also a bunch of work and time to spend!
befor
after first paint with POR15
exotec is offline
Old November 3rd, 2019, 12:28 AM
  #45
Olds Omega
exotec's Avatar
result of the weekend - Upper Control Arms done. waiting for the delivery of new proforged shaft to also install the bushings
exotec is offline
Old November 27th, 2019, 03:07 AM
  #46
Olds Omega
exotec's Avatar
due to the defect Chevy 250 motor block and the either expensive replacement with shipping from US or not successful searching for one in AT/EU the project develops in a different direction!
I found another thrilling machine - a Pontiac 230 OHC sprint will be the future power plant of the Omega!
exotec is offline
Old November 27th, 2019, 04:33 PM
  #47
Out of Line, Everytime😉
olds 307 and 403's Avatar
That is an awesome upgrade, good score. I saw one of those for sale locally as well.
olds 307 and 403 is offline
Old December 24th, 2019, 10:24 AM
  #48
Olds Omega
exotec's Avatar
frontframe is back from sandblasting and powdercoating!
turned out quite nice.
Hope I can finish rebuild the front suspension during the Christmas brake
exotec is offline
Old December 25th, 2019, 10:58 AM
  #49
I can hardly wait to see this come together. I was tempted to pick up a 230 OHC despite the $1000 price tag. The frame looks good. I like any unique, non sheep mentality powerplant and build.
Old December 25th, 2019, 11:27 AM
  #50
The Pontiac OHC 6 was a great engine and still very sought after in the Pontiac community.
oldcutlass is online now
Old December 27th, 2019, 07:09 AM
  #51
Olds Omega
exotec's Avatar
Suspension almost done
exotec is offline
Old January 19th, 2020, 01:33 AM
  #52
Olds Omega
exotec's Avatar
yesterday I pickedup the 1966 Pontiac ohc 230ci - very complete engine!! and my manual 3speed trans will fit as well
exotec is offline
Old January 19th, 2020, 07:34 AM
  #53
Sugar Bear's Avatar
Both your quality of work and progress are impressive!!!
Have you considered dual exhaust? In-line six cylinder engines with dual exhaust can sound good and the exhaust manifolds on the engine make it look doable.
Good luck!!!
Sugar Bear is online now
Old January 19th, 2020, 11:21 PM
  #54
Olds Omega
exotec's Avatar
thank you!
yes, dual exhaust is planned
exotec is offline
Old January 20th, 2020, 04:59 AM
  #55
Interesting choice on the Pontiac OHC L6. This will make it unique for sure. Curious though, I'm not that familiar w/ how these OHC motors go together, but the thermostat housing appears to be built into the cam cover. Is the cam cover part of the water jacket (can't imagine so.....this would mix coolant and lube for the cam, no?)? There must be alot more going on under that cam cover than meets the eye.
Old January 21st, 2020, 04:55 AM
  #56
Olds Omega
exotec's Avatar
I will post some pictures when the cover is off
exotec is offline
Old February 1st, 2020, 08:17 AM
  #57
Olds Omega
exotec's Avatar
front suspension finished today - kept it almost factory, just lowered with BMR springs
exotec is offline
Old March 26th, 2020, 12:40 AM
  #58
Olds Omega
exotec's Avatar
found the build sheet of my Oldsmobile Omega - it was still under the rear bench seat
exotec is offline
Old April 10th, 2020, 04:46 AM
  #59
Olds Omega
exotec's Avatar
maybe a bit too early compared to the status of the rest of the car, but Slavko, my mate from the upholstery shop has same time and started with the work on the bench seats!
the additional wire will/shall improve the stability
both seats will get more lateral guidance
front bench seat:
rear bench seat:
He is doing a lot of jobs for vintage Porsches and therefor he has access to original Porsche fabrics. So we decided to use Porsche Pepita for the middle section and black leatherette for the rest - will almost look like new from Willow Run delivered
exotec is offline
Old April 13th, 2020, 04:21 AM
  #60
Olds Omega
exotec's Avatar
as all mounting points were broken, I will fabricate a new part for my dash bezel myself with fiberglas. Gauges will be most likely the 1967 series from New Vintage USA as the use the same font and red pointer as the original gauges.
between I'll add a 3.5" TFT display with wifi mirroring to display navigation and music - with is playing over bluetooth and the old AM radio - from android and ios devices.
exotec is offline
Old April 13th, 2020, 06:55 AM
  #61
BackInTheGame's Avatar
I like your mock-up! Everything seems to be coming together really well! It will be a sharp ride when you are done.
BackInTheGame is offline
Old April 16th, 2020, 04:22 AM
  #62
Olds Omega
exotec's Avatar
my mate finished the backrest of the rear bench seat - this is just awesome!!!
exotec is offline
Old April 16th, 2020, 05:41 AM
  #63
Looking Good!!!
Greg Rogers is offline
Old April 17th, 2020, 11:38 AM
  #64
Olds Omega
exotec's Avatar
today I joined my mate and we finished the rear bench seat - he is a real master in upholstery!
exotec is offline
Old April 17th, 2020, 11:47 AM
  #65
Frisbee_k9's Avatar
looks so good!!
Frisbee_k9 is offline
Old April 18th, 2020, 02:50 PM
  #66
old80cs's Avatar
Nice work on the rear seat, looks terrific! I like the choice in engine, the Pontiac I6 is going to make many folks double take when they see your hood open! Going to be a cool car for sure!
old80cs is offline
Old April 19th, 2020, 11:35 AM
  #67
Olds Omega
exotec's Avatar
Started to rebuild three on the tree 😁
bearings, switches and levers must be replaced
now of to sand plasting and powder coating
exotec is offline
Old April 25th, 2020, 12:07 PM
  #68
Olds Omega
exotec's Avatar
front bench seat ready, headrests are missing, will be done next week
I love how the backside is made!
exotec is offline
Old April 25th, 2020, 12:51 PM
  #69
Very nice! Looks like you are making great progress. Keep up the great work.
Old April 30th, 2020, 01:07 AM
  #70
Olds Omega
exotec's Avatar
picked-up the most parts from the upholstery shop - gorgeous work! he has a real love on details!
exotec is offline
Old April 30th, 2020, 12:10 PM
  #71
Olds Omega
exotec's Avatar
I‘ll give it a try!
exotec is offline
Old May 27th, 2020, 11:51 AM
  #72
Olds Omega
exotec's Avatar
disassembled!!!
exotec is offline
Old May 29th, 2020, 03:13 AM
  #73
Olds Omega
exotec's Avatar
got mail from Jerry Woodland!
next week pistons, rings and seals should be delivered as well, than the ohc6 rebuild may begin!
exotec is offline
Old August 23rd, 2020, 11:57 AM
  #74
Olds Omega
exotec's Avatar
Was posted yesterday on the OCA Facebook page. This is how my olds looked also when it was new and hopefully will once look again.
he just bought it 2 days ago with orig 25k on it 😍😍
exotec is offline
Old August 23rd, 2020, 12:14 PM
  #75
Killian_Mörder's Avatar
It's a good thing that they were exported without those heavy ugly 5 mile per hour bumpers. The weight saving alone should make your Olds even more fun to drive
Killian_Mörder is offline
Old August 24th, 2020, 01:11 PM
  #76
old80cs's Avatar
Good looking Omega, my best friend in high school had a 73' or 74' with a I6. It wasn't at all fast but the Olds Ralley's made it look great, just like that red car.
old80cs is offline
Old August 24th, 2020, 01:16 PM
  #77
Olds Omega
exotec's Avatar
Yes, the Chevy I6 wasn‘t fast. Mine will be fast with the Pontiac I6 ohc sprint, at least has double hourspower and torque 😁
exotec is offline
Old August 24th, 2020, 01:17 PM
  #78
old80cs's Avatar
Look forward to hearing about how that Pontiac I6 runs!
old80cs is offline
Old August 24th, 2020, 04:12 PM
  #79
Agree, get it done!
Old September 21st, 2020, 09:02 AM
  #80
Olds Omega
exotec's Avatar
Head and block are back from the shop. Now painting it Oldsmobile Gold and polish the cam housing
exotec is offline
Quick Reply: 1973 Omega Restoration with Pontiac ohc6 sprint
