dream engine swap!
Durmax is 1/2 way doable. Cummins good luck. 6BT is way to heavy for the front of that car. Might get away with 4BT weight wise.
Honestly if you have to get on a forum to ask advise about whats involved in a swap like this you don't have the skills to pull it off.
Paying pro will cost 10-20X what the car is worth.
They put a 1000hp twin turbo duramax into a small 66 Nova wagon
....... and a 442/Cutlass engine bay is larger It's "Very doable".
http://ls1tech.com/forums/conversion...ax-diesel.html
http://www.hotrod.com/featuredvehicl...station_wagon/
