Non-Olds Engines For discussion on non-Oldsmobile engines. All forum rules apply.
Frame mounts
Old August 22nd, 2021, 02:38 PM
westside807's Avatar
Frame mounts
Good day!
I'm in the process of swapping to an LS. I purchased chevy frame mounts to replace the olds frame mounts. It appears that I was sent the same mount for both sides. This means that one side has 3 bolts and the other has 4. The olds mounts only used 3. Should I get the correct mounts, or is 3 bolts fine? Attached are the 2 mounts and a pic of what I was supposed to purchase. On that picture notice the holes are slightly different in each mount. I don't have different mounts, I have the same mount with one side having 3 holes. Is it fine/ good only using 3 bolts on a motor mount doing a swap?
3 holes on the bottom
3 holes in top
Only the one on the right has 3 holes.
westside807 is offline
Old August 22nd, 2021, 03:58 PM
I suppose I can just drill the hole through the frame
Old August 23rd, 2021, 12:00 PM
garys 68&72's Avatar
I got a pair of original used ones from a SBC Chevelle and recall they were mirror images of each other.
garys 68&72 is offline
joe_padavano
Tech Editor's Desk
109
March 27th, 2022 06:28 AM
ergot71
February 18th, 2020 05:38 AM
pross4
June 23rd, 2015 08:24 PM
Beob
April 5th, 2011 10:14 AM
procharged70cutlass
December 21st, 2009 09:21 AM
Quick Reply: Frame mounts
