Go Ahead, Call Me Sacreligious
Is there anyone on here running an LS motor on their Olds? I know it's politically incorrect to run Chevy stuff on an Olds car, but I can't help but dream about cheap power for an Olds.
If you did an LS swap, was it really complicated? Tell me all about your LS Olds
Hello Bobby455. I've moved your post to the Non-Olds Engines forum. If you have time to read through some of the posts here I believe you'll be able to connect with others who've gone the LS route with their cars.
John
John
Treat the car like a chvelle buy the ls install kit which has headers oil pan engine mounts etc ., and its pretty straight forward. Thse installs have been made really easy by the aftermarket. Going efi will require more elctrical work but you could run it with a carb and have a stand alone unit ecm for the ignition.
Should be enough to get you started here:
https://classicoldsmobile.com/forums...-iii-swap.html
An LS swap Oldsmobile was just posted on my site for sale. There isn't to much detail about the process but its at least an example.
https://www.oldsmobilecentral.com/fo...lbuquerque.php
76olds
July 5th, 2016 10:36 AM
slowolds
August 13th, 2009 12:18 PM
