Non-Olds Engines For discussion on non-Oldsmobile engines. All forum rules apply.
Ls swap question
Old August 21st, 2015, 01:03 PM
Car Whisperer
SnakeBit's Avatar
Ls swap question
in my 67 330 v8 cutlass...anyone recommend swap motor mounts to use? not sure what to get. seems I have to get 67 chevelle mounting "frames" and then motor mounts for the 67 chevelle, but what about the adapters. any insight would be appreciated.
SnakeBit is offline
Old August 22nd, 2015, 02:14 AM
garys 68&72's Avatar
You'll need chevelle frame mounts and matching poly or rubber motor mounts. Search short/wide, tall/narrow motor mounts. My 72 frame was drilled for both Olds and chevy mounts.
As for the LS adapters. They generally come in 3 varieties that set the motor in the original position (1" setback) or farther forward. A lot depends on the trans you'll be using.
garys 68&72 is offline
Old August 22nd, 2015, 06:08 AM
Rocket Renegade!
You seem like a nice guy, so I'll refrain from saying if you used a proper Olds engine you wouldn't be having this problem.
BangScreech4-4-2 is online now
Old August 22nd, 2015, 08:03 AM
Car Whisperer
SnakeBit's Avatar
Thanx, I am using a 4l60E trans with it. I was looking at these
http://www.dirtydingo.com/shop/index.php?cPath=359_360
and these
http://www.brphotrods.com/products/6...cts/index.html
SnakeBit is offline
Old August 22nd, 2015, 08:05 AM
Car Whisperer
SnakeBit's Avatar
LOL!!! thank you!! I know, just trying to make a nice, easy driver for my son's first car. better mileage, easy of parts and repair. and kind of a cool factor when you open the hood.
SnakeBit is offline
Old August 22nd, 2015, 08:07 AM
Car Whisperer
SnakeBit's Avatar
oh, also looking for recommendations on a quick ratio steering box for the car. places rebuild them and then see things like even a grand cherokee replacement box. this thing is like driving a bus now.
SnakeBit is offline
Old August 22nd, 2015, 08:45 AM
Rocket Renegade!
Best of luck! He'll also probably have the fastest car in school.
Old August 22nd, 2015, 09:33 AM
Car Whisperer
SnakeBit's Avatar
Thank you!!! I hope not on the fastest. the HP is the same for the motor coming out as going in and I am not modifiying it much...maybe a cold air intake. I am not even doing headers on it if I can avoid the expense. he has a friend with a 1962 Impala that his friend's Dad has been doing for him but they just rebuilt the motor that was in it. I am trying to do more of a restomod on this one...old school with new school stuff in it. my son really likes that idea. car has already been fitted for shoulder harnesses, one is in, but I need a longer set and then get the other side too. stereo of course..he keeps bugging me to put subs in it..I tell him we can go and get those anytime at Subway...makes him mad.
SnakeBit is offline
Old August 22nd, 2015, 11:15 AM
1970-W30's Avatar
Of course you realize just because both motors are rated at the same HP, the Olds 330 was rated at what was known as "gross horsepower" and the LS rating is net (actual) horsepower. It definitely will be a lot faster!
1970-W30 is offline
Old August 22nd, 2015, 11:32 AM
Car Whisperer
SnakeBit's Avatar
oh, yeah, forgot about that...been awhile since I heard or talked about gross hp. thanx for the reminder!!!!!!!!!!!! uh oh....hmmm
SnakeBit is offline
Old August 23rd, 2015, 05:54 AM
If you're not following someone elses build for a 64-67, you're best off buying a kit made for a 4L60. You have to balance engine location with trans/tunnel clearance and oil pan/crossmember clearance.
I will say that no one has been happy with the "muscle car"/LH8 oil pan. It hangs too low. Check out a CTS-v or holley oil pan.
and these
Old August 23rd, 2015, 06:18 AM
Car Whisperer
SnakeBit's Avatar
Thumbs up
thanx for that tip!!!! hadn't read about the pan being low. the lh8 pan is advertised alot.
SnakeBit is offline
Old August 23rd, 2015, 08:50 AM
This might help choosing parts. And search for the jeep GC steering box for your 67. I know it works in 68-72 and was the best $50 improvement on the car.
http://ls1tech.com/forums/conversion...2-gm-body.html
Old August 23rd, 2015, 10:04 AM
Car Whisperer
SnakeBit's Avatar
thanx for the info. been trying to figure out which GC box to get. none seem to say what the ratio is and not sure what year to get.
SnakeBit is offline
Old September 12th, 2015, 08:29 PM
Photoshop God
DewChugr's Avatar
I've read 92-98. I picked up a 98 for 35 bucks at the yard. Now if I can just get the arm off mine.
This is supposedly the rag joint you need. Not sure about the fbody, seems odd it would only be two years.
77-82 C/K truck
83-86 2WD full-size GM Truck
77-78 camaro and firebird
DewChugr is offline
Old September 13th, 2015, 01:56 PM
Car Whisperer
SnakeBit's Avatar
I understood it was bolt in, no rag joint needed. thanx.
SnakeBit is offline
Old September 13th, 2015, 02:08 PM
Car Whisperer
SnakeBit's Avatar
looking at this pan
http://www.ebay.com/itm/LS1-LS2-LS3-...6aa9ce&vxp=mtr
SnakeBit is offline
Old September 13th, 2015, 08:11 PM
Photoshop God
DewChugr's Avatar
Not from what I have read. The box bolts up, but it is my understanding you still need the rag joint to mate it with your steering shaft.
DewChugr is offline
Old September 13th, 2015, 08:37 PM
Car Whisperer
SnakeBit's Avatar
thanx. I will have to look for what it is i need.
SnakeBit is offline
Old September 14th, 2015, 05:53 AM
See posts 138 and 139 for GC box parts needed for a 68-72. Not entirely sure on earlier cars.
https://classicoldsmobile.com/forums...ii-swap-4.html
The ebay pan is the LH8 pan that hangs way too low.
Old September 14th, 2015, 10:02 AM
Car Whisperer
SnakeBit's Avatar
Thanx!!!!!!!!!!!!!!!!!!!
SnakeBit is offline
'69CutlassVert'
August 25th, 2011 07:19 AM
61F85Acid
March 26th, 2010 04:55 AM
haack52
December 18th, 2009 08:49 AM
BerBer5985
August 13th, 2009 03:04 PM
SMOKEYMTNKUSTOMS
May 10th, 2006 05:07 AM
Quick Reply: Ls swap question
