Non-Olds Engines For discussion on non-Oldsmobile engines. All forum rules apply.
Pro Touring '72 now going LS2
Old July 16th, 2019, 06:41 PM
  #201
Justin
oldstata's Avatar
What alt and ac brackets did you use ? I skimmed the post but could find what they were, most of the after market one look odd, this set up almost looked like the original olds set up
thanks
oldstata is offline
Old July 16th, 2019, 07:09 PM
  #202
csouth's Avatar
thanks
I used Holley High mount for truck spacing. I have since changed the AC setup to low mount.
csouth is offline
Old July 16th, 2019, 09:03 PM
  #203
70ish's Avatar
Agree with this. i am in the process of swapping to an LS1/T56 and wound up using BHP motor/tranny mounts with Holley 302-1 pan. Stating that i did notice that the BHP mounts sat the engine high and there could be room for the F-Body pan. i do like the clearance for the headers though. You would need to measure and maybe consult BHP.
Ed
70ish is online now
Old July 17th, 2019, 09:14 PM
  #204
csouth's Avatar
You mean BRP mounts? Most of these mounts with non adjustable position are made around a specific pan, assuming you don't move the position on the frame.
csouth is offline
Old December 20th, 2019, 11:41 AM
  #205
csouth's Avatar
Haven't posted any updates in a while. Installed LS3 heads and a BTR cam on the car this summer, runs great, I also decided to start my LSA conversion. I needed new inner fenders also so I decided to go with the red ones. Car should be ready to fire up again mid January at the latest.
csouth is offline
Old December 20th, 2019, 12:31 PM
  #206
Nice work, look forward to hearing it run.
oldcutlass is online now
Old December 20th, 2019, 06:28 PM
  #207
dc2x4drvr's Avatar
Nice, clean job..
dc2x4drvr is offline
Old December 20th, 2019, 09:09 PM
  #208
csouth's Avatar
It's pretty mellow right now, so it will probably just have that little SC whine
Nice, clean job..
Thanks. I'm going to get all my hoses routed and i have to install my PS reservoir and new catch can. Always fun...
csouth is offline
Old March 15th, 2020, 07:09 PM
  #209
csouth's Avatar
Haven't been updating this in a while. Now that my hoses are routed and everything else is in place, its time to clean up my wiring. Need to mount the ECU again a loom my fan controller wires. Waiting for more braided wire loom and it should be quick. I also tapped my lid and ran hose for boost reference needed by the fuel pressure regulator.
csouth is offline
Old February 14th, 2022, 09:06 PM
  #210
csouth's Avatar
Its been a LOOOOOOONG time since I posted anything here, so I will update with the condensed version: the car was tuned, and put on the road. I ended up wrapping the car in satin white for summer 2019....
I took the car off the road in fall 2019. The person i wanted to paint said he really didn't have the capacity to do my paint and body, but did agree to do my quarters. Removed the wrap and had the quarters replaced.
In Jan 2021, I found another shop that was able to get me in for body and paint... Dropped her off and waited for the final results...
csouth is offline
Old February 14th, 2022, 09:10 PM
  #211
csouth's Avatar
Finally brought her home...
csouth is offline
Old February 15th, 2022, 06:31 AM
  #212
jozw30's Avatar
So cool!
jozw30 is offline
Old February 15th, 2022, 06:40 AM
  #213
72 Olds CS
RetroRanger's Avatar
That looks real good Chris. So its all together and running now? Just needs final reassembly? Any stripes or other plans?
RetroRanger is offline
Old February 15th, 2022, 12:14 PM
  #214
csouth's Avatar
Thanks....Yeah, I actually took it off the road to do the paint. It has very faint ghost stripes on the hood, but nothing other than that...
csouth is offline
Old February 16th, 2022, 03:59 PM
  #215
Loaded68W34's Avatar
That thing looks amazing. Some blue lines from diamond back would really finish it off. Especially with the calipers
https://dbtires.com/product-category...ype/bluelines/
Loaded68W34 is offline
Old February 16th, 2022, 06:35 PM
  #216
I absolutely love the silver. Car looks great. 👍👍🍻
no1oldsfan is offline
Old February 18th, 2022, 12:52 PM
  #217
csouth's Avatar
I've seen the DB stuff before. I think they would look good with a different wheel.
Thanks, I saw it on another car and immediately know it was the one....
csouth is offline
Old October 22nd, 2023, 07:32 PM
  #218
csouth's Avatar
So the car sat on the back burner for most of this year. The shop I wanted to do the wiring had a spot open up where they could get me in so I jumped at the opportunity. Should be finished in a couple weeks then off to interior.
csouth is offline
Old March 31st, 2024, 08:06 PM
  #219
csouth's Avatar
Wiring was done for a while and I'm very happy with the results. The did a complete universal body harness using American Auto Wire HWY 22 kit. The shop doing the work preferred the universal harness over the Classic Update. Before taking it in I had already installed the power windows, remote door lock actuators and moved the battery to the trunk. Also included was:
Aux Fuse/relay panel in engine bay for hx pump and fans
Aux fuse panel under the console for USB port power
remote trunk release wiring
wiring of electronic parking brake actuator control box
ground bar behind dash
Dakota Digital
Vintage Air
main power
Trunk mounted battery with cutoff
csouth is offline
Old March 31st, 2024, 08:13 PM
  #220
csouth's Avatar
I also had them clean up the wiring in the engine bay and make me a custom air intake tube. Just waiting to go to interior shop now...
Mounted ECU to fender
csouth is offline
Old March 31st, 2024, 10:01 PM
  #221
car guy
gearheads78's Avatar
looking great!
gearheads78 is offline
Old April 1st, 2024, 08:30 AM
  #222
csouth's Avatar
Originally Posted by gearheads78
looking great!
Thanks! I'm getting a little antsy... I won't relax until my interior guy tells me to load up the car and bring it down!....lol
csouth is offline
Rocket 442
September 8th, 2021 07:09 PM
flatoz
25
September 19th, 2019 10:37 PM
firefighter5174
Non-Olds Engines
134
July 28th, 2017 07:31 PM
manny72supreme
December 1st, 2011 03:05 PM
Jocko124
May 15th, 2011 09:30 PM
Quick Reply: Pro Touring '72 now going LS2
