Non-Olds Engines For discussion on non-Oldsmobile engines. All forum rules apply.
SBC 350 PCV question
Old May 17th, 2015, 02:27 PM
Rocket "Scientist"
Dead Reckon's Avatar
So I got a second hand Holley 1460 (80508-3) 750CFM, works great, but there is no port for the PCV valve on my engine to pull vacuum, only one for the brakes. It was on a Ford, and I know they pull from the manifold, so I dunno if that matters, but it's otherwise completely fine. Was gonna put this carb on the '79, but I really like the way it runs so the '79 will get the Summit 600.
I tried using a T to make the PCV pull from the same vacuum as the brakes, but my brakes really sucked when I did that, not enough vacuum I guess.
Where else can I hook up the PCV valve? The only ports on the carburetor as follows:
1 ported vacuum for distributor advance
1 manifold for transmission
1 manifold for brake booster
The base plate has a flat spot where there should be another vacuum port, but there is not. I have an adapter under it that adapts it from square to spread bore, I was thinking I could either drill that or put a T on the manifold vacuum source at the heater vacuum port. Any ideas?
Thanks,
-Ben
Dead Reckon is offline
Old May 17th, 2015, 03:33 PM
The PCV is a big vacuum leak, so it needs to connect at the base of the carb and not on an individual cylinder runner. Putting it on a runner would likely cause a lean misfire on that cylinder. Drilling the adapter would be my choice.
Fun71 is online now
Old May 17th, 2015, 03:38 PM
Rocket "Scientist"
Alright I'll have to do that as soon as possible. I can't really do anything about it right now, after putting gas in my car for the week and buying the Holley I'm broke
I wasn't sure if I'd get good vacuum from the adapter or not, but now I know, thanks for the info.
Old May 17th, 2015, 04:26 PM
Can you tie the brake booster directly to the manifold? Then connect the PCV where the brake booster was connected.
oldcutlass is online now
Old May 17th, 2015, 07:16 PM
Rocket "Scientist"
I literally have no idea why I didn't think of this.. Where is the facepalm smiley? I'll have to get a T with a large and small side, as the vacuum line for the climate control is rather small, could probably fit in the line for the brakes.
Upon reading this I literally had the realization that I may have spent a bit much time spray painting today, even with a good mask it kind of messes with your head.
Old May 18th, 2015, 01:32 AM
Oldsragger's Avatar
That was my tought too.
Have u a project tread about the black delta btw?
Oldsragger is offline
Old May 18th, 2015, 08:29 AM
Rocket "Scientist"
No, I'm kinda lazy like that, sorry.
I can start one if you like though. I can easily look up all the parts I've put on.
Dead Reckon
Non-Olds Engines
December 7th, 2014 02:55 PM
papanewgz
October 6th, 2014 05:34 PM
Pacecar
December 22nd, 2012 08:24 AM
ATrain1
Non-Olds Engines
June 24th, 2012 12:04 PM
the_duke
April 30th, 2011 11:14 PM
Quick Reply: SBC 350 PCV question
