Non-Olds Engines For discussion on non-Oldsmobile engines. All forum rules apply.
Vortec Headed 355
Old June 10th, 2022, 04:23 AM
VORTECPRO's Avatar
Vortec Headed 355
My son was able to get to the track with his 355 Camaro recently, very similar type of build as Copper Cutlass's type of build but the Chevrolet version. His combination used a unported L31 Vortec head, 1.940/1.500 valves, .435/.460 lift hyd flat tappet cam, with a Diamond dished piston. Intake was a Vortec Super Victor with a 750 Holley. Track conditions were: 98 degrees, 120 grains of water, 29.20 barometer, 3200 feet DA, I was very happy with his first outing. Its worth pointing out the Vortec headed 350 can be be a stout low dollar power maker for sure. This fall when he can get into some very good conditions I will report back. 1/8 mile times. BTW running weight is a light weight 3200 pounds.
1.373 60 foot
6.81 660
97.5. MPH
VORTECPRO is offline
Old June 10th, 2022, 04:50 AM
oldsmoboogie's Avatar
Cool, what transmission? Stock rear?
oldsmoboogie is offline
Old June 10th, 2022, 05:30 AM
VORTECPRO's Avatar
12 bolt 4.88 gear with a Metric 200 trans.
Old June 10th, 2022, 05:23 PM
Interesting choice in transmission, what does the converter flash at? What is the duration and lsa of that cam?
Old June 11th, 2022, 10:44 AM
VORTECPRO's Avatar
5200 Flash
258 @ .050
106
Old September 1st, 2022, 08:40 PM
68post's Avatar
Vortecs have a reputation of being able to handle some compression with only pump gas so why a dish with only 355 cubes ? I guess I should inquire what the actual compression is and perhaps I'll have my answer !? What fuel is he on ?
Definitely respectable times, what would be your/his next change on this engine - if any, or the car ?
68post is offline
Old September 2nd, 2022, 10:45 AM
VORTECPRO's Avatar
This Camaro was built to run in IHRA G/CM class. G crate is: the GM performance 330 HP Vortec headed 350, it must use the factory type piston which has a dish. The cam must also be factory lift which is .435/.460 hyd flat tappet.
Old September 4th, 2022, 01:24 AM
68post's Avatar
Thanks for the info !
68post is offline
Old October 31st, 2022, 06:02 AM
VORTECPRO's Avatar
UPDATE
Had the Camaro out Sunday, went 10.79 @ 121.39 with a horrible 1.42 60, 7700 RPM through the lights, new tires next, looking for 10.60s, trans overhaul then 10.5s.
Old October 31st, 2022, 10:00 AM
1975 98 Regency Sedan
harner's Avatar
That's a lot of steam! As a 4th gen owner, I'm curious - what is the suspension setup?
harner is offline
Old October 31st, 2022, 08:55 PM
VORTECPRO's Avatar
I run a 12 bolt, moly heim lower bars, with a adjustable TQ arm, Santhuff shocks, best 60 foot 1.36
randomarrival
October 4th, 2023 09:23 AM
olds 307 and 403
May 6th, 2021 06:29 PM
ajr2820
April 20th, 2021 06:41 PM
RocketV8
June 11th, 2016 03:05 PM
380 Racer
June 4th, 2013 04:09 AM
Quick Reply: Vortec Headed 355
