Non-Olds Engines For discussion on non-Oldsmobile engines. All forum rules apply.
Vortech 5300 ls swap in a 65 cutlass
Old April 21st, 2012, 02:58 PM
65-F85's Avatar
Has anyone put the votech 5300 ls 5.3 in a 65 cutlass. Due to the engine being out of a truck (05 Z71) the intake is taller. My mesurements make it apear very close. Does anyone kow for sure?
Thanks Gary
65-F85 is offline
Old April 21st, 2012, 03:05 PM
deejai35's Avatar
Hey Gary, welcome to the site. Check out the non Oldsmobile powered section. There have been quite a few LS swaps and a wealth of info there.
deejai35 is offline
Old April 21st, 2012, 11:17 PM
garys 68's Avatar
When I put a 5.3 in my 72, I swapped out the intake for an LS1 because it looked close. Check over at LS1tech conversion forum for your car. Pretty sure someone's done a 65.
https://classicoldsmobile.com/forums...-iii-swap.html
http://www.ls1tech.com/forums/conver...2-gm-body.html
garys 68 is offline
Old April 23rd, 2012, 12:07 PM
panos's Avatar
Just for reference, i have a vortec 5700 in my `65 now with a single plane high-rise intake and it fits under the hood with a drop base aircleaner.
panos is offline
Old April 23rd, 2012, 12:51 PM
panos that looks awesome! Do you miss the 455?
oldcutlass is online now
Old April 24th, 2012, 12:13 PM
panos's Avatar
Well yes and no,i miss the torgue at low rpm,but the chebby makes it out with more revs,10:1 comp and a hyd.roller with 500/510 LIFT .225/231 DURATION @.050" 110º LOBE SEP.
Im still working on a plan to rebuilt the 455 though
panos is offline
Old April 28th, 2012, 02:25 PM
panos's Avatar
Here i a short clip from today cruising,the interesting part is the car in front of me,a `72 W30 cab.(clone) but real nice nontheless,bad quality and shaking but i was driving and filming at the same time
http://youtu.be/nv96dr_g64E
panos is offline
Old April 28th, 2012, 06:22 PM
I bet you guys attract all kinds of attention cruising around there!
'69CutlassVert'
August 25th, 2011 07:19 AM
olds70supreme
August 1st, 2011 05:22 PM
<jimmy>
November 18th, 2007 02:09 PM
macarthur
January 10th, 2007 05:19 AM
skibone
April 15th, 2004 03:13 AM
Quick Reply: Vortech 5300 ls swap in a 65 cutlass
