Non-Olds Engines For discussion on non-Oldsmobile engines. All forum rules apply.
Are you a mechanic?
Old August 15th, 2011, 11:04 AM
Rickman48's Avatar
Are you a mechanic?
While a service writer at a Chevy dealer almost 30 yrs ago, ran into this problem our 'Master Mechanic' couldn't figure out!
I may have mentioned it before, but I hope not.
Vehicle; '78 Chevette 2-dr, 58,000 miles, driven 20 miles 1-way to work.
Complaint; After [cold-start] 3.5 miles engine stalls. Cranks, but will not start. After sitting 5 min., starts and will run all day, even after sitting 9 hrs. at work. No smoke or noises from engine.
Attempted repair; Switched carb and distributor from another chevette with close miles - NO computer on vehicle. Didn't affect stalling at all.
Thankfully, this guy was almost bald, as he was ready to tear his hair out!
He drove it home for a week, and it still did the same thing!
I made a suggestion and it cured the problem - let's see who can figure this one out!
Rickman48 is offline
Old August 15th, 2011, 11:18 AM
PM sent (don't want to spoil it if I'm right).
Anything we should know about weather / temperature, etc.?
MDchanic is offline
Old August 15th, 2011, 11:26 AM
Rickman48's Avatar
Stalled @ 3.5 miles, 90 above to 10 below, rain or shine!!
Old August 15th, 2011, 11:28 AM
Where were you in '72?
boondocker's Avatar
Fuel pump or filter?
boondocker is offline
Old August 15th, 2011, 11:42 AM
CQR
CQR's Avatar
Wrong gas cap causing a vacuum.
CQR is offline
Old August 15th, 2011, 11:44 AM
Rickman48's Avatar
Nope!!
Old August 15th, 2011, 11:52 AM
defiant1's Avatar
Gas tank vent clogged.
defiant1 is offline
Old August 15th, 2011, 11:57 AM
Rickman48's Avatar
Not fuel or spark related - he changed the carb and dist. without effect - think variables!
Old August 15th, 2011, 12:06 PM
defiant1's Avatar
Torque converter lockup or bad TVS switch (if it had one of those)
defiant1 is offline
Old August 15th, 2011, 12:13 PM
Tony72Cutlass'S''s Avatar
Choke Linkage messed up? Or something Choke related? Sounds like it's almost counter-intuitive?
Tony72Cutlass'S' is offline
Old August 15th, 2011, 12:14 PM
Wait nevermind, you say he changed the carb...
Old August 15th, 2011, 12:15 PM
Okay, my second attempt was this:
A particularly steep hill at that point on his trip, either up or down, pushed the fuel away from a defective fuel tank pick-up. Once stopped, perhaps the usual sloshing stopped, and the fuel pump was able to draw enough fuel to continue.
Could also apply for a particularly long off-ramp if he was a fast driver.
MDchanic is offline
Old August 15th, 2011, 12:48 PM
CQR
CQR's Avatar
OK, If this is true ^^^^ Than the car is losing compression and 5 minutes later is regaining compression to start. So how about gear lube in the crankcase causing valves to hang open?
CQR is offline
Old August 15th, 2011, 01:17 PM
Oldsdruid
rocketraider's Avatar
I'm leaning toward an oil pressure switch or fuel pump relay, though it's odd the thing would start and run the rest of the day without problems.
Then again an uncle had a K-car Town & Country wagon that would do almost the exact same thing and even Chrysler Zone Service couldn't figure that one out.
rocketraider is offline
Old August 15th, 2011, 01:52 PM
garys 68's Avatar
I had a chevette...... did you suggest he just abandon it next time it stalled?
garys 68 is offline
Old August 15th, 2011, 01:58 PM
WHIPOLDS's Avatar
Was it the coil?
WHIPOLDS is offline
Old August 15th, 2011, 02:11 PM
TripDeuces's Avatar
Anti-theft device from previous owner.
TripDeuces is offline
Old August 15th, 2011, 02:26 PM
CQR
CQR's Avatar
I LOL'ed at that. ^^
CQR is offline
Old August 15th, 2011, 02:29 PM
Don L/442's Avatar
The first thing that comes to mind is a fuel or spark problem. But if that is not so then is it a vacuum issue.
Don L/442 is offline
Old August 15th, 2011, 02:34 PM
Stevec's Avatar
Bad egr valve?
Stevec is offline
Old August 15th, 2011, 03:43 PM
Redog's Avatar
I'm going to say vacuum related since fuel and spark are not the issue.
I'm wondering if the car had one of those valves on the exhaust manifold and it was stuck closed, but the thremal heat switch read "hot" and opened up the valve after the restart
Redog is offline
Old August 15th, 2011, 05:54 PM
stellar's Avatar
low oil
stellar is offline
Old August 15th, 2011, 06:08 PM
compedgemarine's Avatar
well the main problem is that it is a Chevette. after that nothing else really matters.
compedgemarine is offline
Old August 15th, 2011, 06:17 PM
zodiacblueS's Avatar
Probably a bent Johnson Rod.
zodiacblueS is offline
Old August 15th, 2011, 06:30 PM
Don L/442's Avatar
Would wooden clothes pins on the fuel line help reduce vapor lock?
Old August 16th, 2011, 08:23 AM
Rickman48's Avatar
CQR is close!
I've got a laptop on it's last legs - hard to get on!
Old August 16th, 2011, 09:45 AM
boondocker's Avatar
Gum and carbon buildup on valve guides...need an additive to clean
Old August 16th, 2011, 05:38 PM
oldzy's Avatar
I had a similar prob with a '90 Regal. Prob was corroded wires here and there. Fun stuff.
oldzy is offline
Old August 16th, 2011, 06:21 PM
stan 65 cutlass's Avatar
my dad told me of a similar thing, turned out when the old gal got in the car she pulled out the choke *** to hang her purse on, when she left the car she pushed it back in so it drove the mechanics nuts
stan 65 cutlass is offline
Old August 16th, 2011, 06:23 PM
hey look three canadians in a row what are the odds
Old August 16th, 2011, 06:55 PM
  #31
Let's do 4 in a row. The Chevette didn't have a manual choke. Although I would honestly say that many times I wanted to choke the living $hit out of the one I had. It would start everytime and run (rather loudly) get up to a blistering 65mph almost floored and had the worst defroster in cold weather.
So, being absolutely no mechanic, I'm going out on a limb and saying that the problem with the car was with the catalytic converter flapper valve off the exhaust manifold. Take out the flapper and you're good to go.
Allan R is offline
Old August 16th, 2011, 08:06 PM
  #32
boondocker's Avatar
My sisters '80 Acadian (Ponitiac Chevette) ran forever...couldn't kill that old "Iron Duke".
Old August 16th, 2011, 08:37 PM
  #33
Rickman48's Avatar
Catalytic converter flapper valve?? That's a new one!!
Turns out, GM, [not just Chevrolet] deceided lower valve spring pressures would reduce [?] friction, and had about 70# pressure on the seat, when new.
With a 195 thermostat, the spring would eventually loose tension, and not have much pressure at a certain temp, ie - wouldn't seat the valve.
Why more heat would give the spring more tension is beyond me, but fresh springs solved the problem.
About a week later, another guy with a chevette complained about almost the same problem - I quoted $150, and took the car in.
Service Manager blew up, and told me if that wasn't the problem, I'd have to pay for it!
Never saw either of them again! GM issued a "bulletin" about valve springs about 2 weeks later.
Old August 16th, 2011, 08:56 PM
  #34
Talk about surprise endings!
MDchanic is offline
Old August 20th, 2011, 11:39 PM
  #35
Rickman48's Avatar
I'm surprised Joe didn't figure this one out!!
Old September 21st, 2011, 06:40 PM
  #36
toymobile's Avatar
Had a like prob with a GEO, ran hot blew, head gasket, reworked head, changed the oil to clear warter, smarty me put 20W50 oil, would start and run 5 sec stall start again after sitting 15 min ran fine,took awhile to figure the oil was to thick, valve springs couldn't close valves, replaced with 5W20 as recomended, NO MORE STALL,, Good story,Later Johnny
toymobile is offline
Old March 30th, 2012, 05:18 AM
  #37
my442conv's Avatar
78 vett
pm sent
my442conv is offline
65f85
September 24th, 2009 07:51 PM
65az
March 19th, 2009 01:49 AM
71CutlassSupreme
March 18th, 2009 09:28 AM
71rocket
February 3rd, 2009 05:02 AM
ChrisM
February 28th, 2008 04:55 AM
Quick Reply: Are you a mechanic?
