Non-Oldsmobile Classified Please read forum guidelines before posting.
BBC Forged Crank
Old January 13th, 2021, 06:25 AM
Magna86's Avatar
Unknown Crank
Deleted
Magna86 is offline
Old January 13th, 2021, 03:56 PM
ROCKETMAN269V's Avatar
BBC Forged Crank
Are you sure that's a BBC crankshaft? Somehow the keyways don't look right.
ROCKETMAN269V is offline
Old January 13th, 2021, 05:51 PM
nsnarsk65cutlass's Avatar
That does not look like a big block chevy crankshaft.
nsnarsk65cutlass is offline
Old January 13th, 2021, 09:16 PM
Lonnies Performance's Avatar
Looks more like a Chrysler Big block 413-440 RB stroker crank.
Lonnies Performance is offline
Old January 14th, 2021, 02:56 AM
Magna86's Avatar
If I am wrong let's identify it. I'm going off what another member said. Would a picture of the flywheel flange help? If it a different crank what's it worth so I can find a new home for it.
Magna86 is offline
Old January 14th, 2021, 04:50 AM
It appears to have an 8-bolt flange on the back; definitely NOT BBC. I know the Mopars used that pattern. How about the casting #? Then we could solve the mystery. Thanks, Bob.
Old January 14th, 2021, 06:06 AM
Magna86's Avatar
There are no casting numbers or lines on the crank. Only numbers are whats stamped into the counterweight that I listed in the original post. Its aftermarket but I don't know by who.
Magna86 is offline
Old January 14th, 2021, 09:46 AM
Magna86's Avatar
Magna86 is offline
Old January 14th, 2021, 05:28 PM
MOTORHEAD
11971four4two's Avatar
Hey MAN
Why did you not take it to a machine shop
the ones I saw with 2 keyways were on blower engines Just saying
This is NO an Oldsmobile part
11971four4two is online now
Old January 14th, 2021, 05:34 PM
.........This is NO an Oldsmobile part
It's NOT listed as an Oldsmobile part.
Old January 14th, 2021, 08:15 PM
MOTORHEAD
OK
tell me what it is
douce
Old January 14th, 2021, 09:13 PM
MOTORHEAD
This was an Oldsmobile website..
Old January 15th, 2021, 04:27 AM
"Non-Oldsmobile Classified"
Old January 15th, 2021, 05:34 PM
Magna86's Avatar
Rods are 2.38 and mains are 2.70 if this helps anyone I'd this crank. This is with tape and a tape measure then divide by π
Magna86 is offline
Old January 15th, 2021, 07:25 PM
Why don't you do some research & look at the Chrysler crank I mentioned.... Maybe you will find your answer.
I'm trying to help you, but it is your responsibility not to misrepresent something, not mine.
There is not a casting number because it is not a CASTING but an aftermarket forged crank.
Aftermarket cranks did not typically have forged in numbers but stamped numbers as you showed..
It has a dual keyway as it was likely built for a supercharged application.
Old January 15th, 2021, 08:46 PM
Magna86's Avatar
Reposted thread closed
Found out it's a top fuel crank that can't be run in a street motor unless machined for pilot bushing/ torque converter
Magna86 is offline
Magna86
January 15th, 2021 05:35 PM
mfgusa
March 14th, 2017 02:02 PM
joe_padavano
August 6th, 2015 01:49 PM
citcapp
April 23rd, 2011 10:01 AM
BosMobile
May 21st, 2009 01:09 PM
Quick Reply: BBC Forged Crank
