1969 radiator support
Old September 8th, 2019, 04:54 AM
jerryl's Avatar
I have a 1969 442 with a rusty radiator support, I also have a 70 support in great shape, I compared the two and they look similar with exception of latch area .my question is ,can latch from 69 be adapted to 70 support ?
Last edited by jerryl; September 8th, 2019 at 10:08 AM. Reason: move to general discussion
jerryl is offline
Old September 18th, 2019, 05:43 AM
rocketscientis's Avatar
interchangeability
Same hood.why not....ever c 66 front clip then 67 tail ligjts
Basically it will depend mostly on your skillz /abilities level multiplied by determination
Knock em dead !
rocketscientis is offline
Old September 18th, 2019, 06:26 PM
CH3NO2 LEARN IT BURN IT
droldsmorland's Avatar
I've not personally performed this, but here is what I know...
Choice 1. Put a 70 hood on it with the 70 support.
Choice 2. Find another good 69 support. Many people want to put a 70 OAI hood on a 69. This requires the 70 support installed on the 69.
Choice 3. Could be to cut out the rot and graft in the good metal from the 70. Not sure if those areas are the same. You"ll have to compare.
Follow up here with what worked to close the loop. Makes the search feature work better.
droldsmorland is offline
jerryl
September 8th, 2019 10:05 AM
Cincinnati Rick
October 22nd, 2016 03:38 AM
Bitburger
January 30th, 2016 07:42 AM
grmchne78
September 18th, 2015 04:14 AM
j_link
August 5th, 2014 10:51 AM
Quick Reply: 1969 radiator support
