1972 Cutlass fan clutch --replacement
Old April 14th, 2024, 08:33 PM
Big Kid with the Cutlass
Jersey Chris's Avatar
I have a 1972 Cutlass ( non-AC) that had a frame off 20 years ago.
Doubt the bad fan clutch I just pulled out was the original HD Thermal clutch.
FYI- the 350cu was "worked" ( big cam, bored & channeled, etc etc) so I want to make sure a put in another Heavy Duty clutch
( car also has a 3 row radiator that I am adding a shroud to.
Everyone in the Olds groups I am in says get a Hayden HD. I found 2 on RockAuto ( 2747 and the low profile 2947). I measured the one I pulled out, which matched up in depth with the low profile, but it looks nothing like it. The Hayden is clearly bigger in overall diameter, beefier?, However bolt pattern to water pump matches up. Look at pictures below.
Also, here is a link to the only HD clutch on the internet that looks like the one I just pull out; look at front and back. it's almost exact:
https://www.thepartsplaceinc.com/pro...diameter/64484
And here is a link to one I just got in from Jegs that looks a lot bigger than the old one ( even shaft is thicker)
https://www.jegs.com/i/Derale/259/22...g+Confirmation
old one on right; yeah I just noticed the shafts are different.
Jersey Chris is offline
Old April 14th, 2024, 09:25 PM
4speed455's Avatar
I used the Hayden 2705 for my 70 Cutlass with 455. It looks pretty close and a lot cheaper then the one you found.
https://classicoldsmobile.com/forums...-455-a-157790/
4speed455 is online now
Old April 14th, 2024, 11:45 PM
Was there a question somewhere?
I say bolt that fan clutch on and see how it performs.
Fun71 is offline
Old April 15th, 2024, 05:20 PM
So you have the Hayden 2705 which is a Standard clutch and not a Heavy Duty like the ones in W-30's and it keep's the motor cool?
I've actually been looking to add a HD clutch as my car runs hot in traffic
Old April 15th, 2024, 05:44 PM
'72 Cutlass ragtop
70sgeek's Avatar
I use a 215046 (Carquest) standard duty - the 2 HD units you mentioned will also fit (be sure in any case to use the sleeve that they come with to ensure a proper fit onto the water pump stem
70sgeek is offline
Old April 15th, 2024, 05:55 PM
Thank you
jpayne_80@hotmail.com
May 30th, 2022 06:54 PM
tkcutlass
March 28th, 2022 08:01 AM
jpc647
December 16th, 2016 06:21 AM
Macadoo
August 17th, 2014 05:09 PM
ztim
May 6th, 2007 12:23 AM
Quick Reply: 1972 Cutlass fan clutch --replacement
