61 Starfire (Starter Rebuild or Not)
I think I need to rebuild my starter what do you think?
Symptom:
When starting the car the starter cranked the engine correctly, I have not run her in a while so I did what I always did, that is I let it crank a few times lest the a 20 sec duration (gets the oil pumped up).
The car started fine.
After warming up I stalled her. When trying to restart the started seemed to never engage, so I paused for a moment tried once more, same thing. I paused once more then it engaged and started.
I figure it’s really the bendix drive but if I pull the starter I am rebuilding everything.
Ben
Symptom:
Ben
Are you saying the starter motor spins but doesn't contact the flywheel to spin the motor? That sounds like a bendix alright. And I'd go with ozone's suggestion to go through it. Replace the solenoid, too.
C.J.
C.J.
Tedd Thompson
March 21st, 2015 01:32 PM
James A Shaw
October 17th, 2013 06:30 PM
