'75 Oldsmobile 98 Climate Control Questions
Old March 8th, 2024, 05:14 PM
SirVelociraptor's Avatar
As luck would have it, my heater core developed a leak. Fortunately getting the under-dash encasement removed was not as hard as I thought or as bad as the FSM made it out to be (There was now way I was pulling the dash-pad and tearing the ducts out as recommended). The core itself is overall in good condition, minus the small pinhole that can be easily fixed (thankfully). While I have the majority of the climate control system pulled, I was wondering if there's anything else I should look at or service while it's out? The foam on the doors is severely degraded and at the very least needs cleaned off. Is it worth going through the effort replacing?
Additionally, this is also a Tempmatic equipped car. I'm unsure if the its operating as intended as while it seems to maintain temperature when set to around 70, increasing it above 70 just causes it blast 90-degree air at you, regardless of cabin temp. Are there any things I should look at for defects or parts I should replace on the Tempmatic unit itself?
SirVelociraptor is offline
Old March 9th, 2024, 03:28 AM
Verify the condition of the vacuum hoses going to the AC control head. GM used vacuum hose with a colored stripe to control air doors in the plenum. If these are rotten your AC won't work right even if you have a full charge of R12.
Olds64 is online now
Jyelinek
January 15th, 2021 02:12 PM
Hdmike444
December 4th, 2019 04:53 AM
Dream Whip
August 9th, 2016 02:59 PM
Skeetman
January 5th, 2015 10:02 AM
russellprocissi
April 16th, 2014 01:14 PM
Quick Reply: '75 Oldsmobile 98 Climate Control Questions
