air scoop fittment
I am probably putting my foot in it, because I have no personal experience with this. the engine compartments changed very little, and I believe bumper brackets are common. Others have the cars with the ducts to confirm, but I think they mount off the fender and bumper brackets. They should fit, but some light fabrication would probably be needed.
At worst you will need to tweak the brackets, but there is nothing to prevent it. Note that the windshield washer tank needs to go on the passenger side inner fender to clear the ram air tubes and if you have A/C the ducting may not clear the compressor (A/C was not offered on the 66-69 O.A.I. cars for this reason).
Here's a pic of a 69 W-32 with ram air and a/c. Is this a fake?
http://cgi.ebay.com/ebaymotors/Oldsm...=p4506.c0.m245
Out of curiosity, isn't the engine supposed to be red on the hi perf cars? I also thought it odd that the engine compartment looked awfully fresh for the guts to look so tired. back to the color question I thought pre 70 hi out put engine were red, correct?
The only red one I know is the 455 in a 69 H/O
I may be wrong, but I believe the air ducts would come up from under the core support. the bulk of the labor should be fitting the scoops to the bumper brackets. But this is coming from a guy who has only glanced at it in a book.
Well the scoops and air cleaner snorkel sold on ebay for around 500. I need to research fittment on my 71 further. I also wonder if it would give you seat o the pants take notice.
Off the line you wouldn't notice a thing. I believe the most you would get out of it would be improved E.T's at the track. and altered fuel economy. I'm not sure if it would be better or not, But the ego factor shoots up! At low speeds you are not adding enough pressure to alter the effective displacement of the engine enough to notice. Increase the go factor and that changes.
The cool factor is way up with these scoops.
By z11375ss, shot with Canon EOS DIGITAL REBEL XTi at 2008-10-23
The hoses go through the plastic wheelwells. There are holes cut into them. The bracketry is all you need, and of course a dual snorkel air cleaner. Good Luck! Jim
By z11375ss, shot with Canon EOS DIGITAL REBEL XTi at 2008-10-25
By z11375ss, shot with [URL=http://profile.imageshack.us/camerabuy.php?
Don't they make repops? Wouldn't mind getting something like that for mine, but am not willing to pay the going rate for original. The work I do and profits, or lack there of are closely tied to the economic environment. Which obviously is not good right now.
Last I time checked, the repos don't come with a template to cut the holes...................so ya gotta be careful cutting into those nice new red fender wells
1k442
October 3rd, 2012 08:44 AM
1k442
March 30th, 2012 11:55 AM
