A/C Code 66 (low freon) at speed, but not at idle.
Old May 30th, 2007, 02:16 AM
awdavis01's Avatar
Getting a code 66 (low freon) on my 1992 Regency Elite after conversion from R12 to R134a. Pressure is good, so I replaced the a/c pressure switch on the accumulator suspecting it to be the culprit. Car can site at idle for 30+ minutes, 60 degrees max fan, without an issue and compressor cycling at 10 secs on, 2 off. But as soon as you drive away within a mile it will gen a code 66 again. Been through AllData without any progress. Any comment would be appreciated.
awdavis01 is offline
Old May 30th, 2007, 04:56 AM
ozoneblue's Avatar
still sounds a little low are you useing guages ? if so what is the low side reading at idle
ozoneblue is offline
Seff
September 20th, 2012 04:46 PM
73rocketship
July 6th, 2012 06:45 AM
Lady72nRob71
July 4th, 2011 05:49 PM
mmurphy77
June 4th, 2010 08:40 PM
awdavis01
Ninety-Eight
June 7th, 2007 02:08 AM
Quick Reply: A/C Code 66 (low freon) at speed, but not at idle.
