Evaporator Coil Replacement
Old October 7th, 2021, 03:25 PM
Phoenix8990's Avatar
The AC didn't work in my 69 Cutlass when I got it so I had it charged, it had been updated to the new freon, and it blew a nice 45 degree air, for about a week. The evaporator coil has a leak and will need to be replaced. I watched a youtube video for a 69 GTO as it was the closest I could find. It gave me a close idea what I'm in for and looks like a lot of work. I looked in the CSM to see if it covered the removal and I didn't see anything. Is there a step by step or video out there showing how to do this? I will need to replace the heater coil while I'm at it.
thanks,
Steve
Phoenix8990 is offline
Old October 7th, 2021, 05:49 PM
mister442's Avatar
The evap core is on the outside heater core is on the inside, You only need to remove the engine side of the case ,I replaced mine in my 1970 Rallye 350 start to finish in about 2 hours the evap core came from the parts place exact match to the original G,M.
mister442 is offline
Old October 7th, 2021, 06:06 PM
Thats really good news
thanks,
Steve
Old October 8th, 2021, 06:55 AM
oddball's Avatar
Yup, key is getting access around the engine to remove that half of the evap case. It's OK if you have a small block, much more of a headache with a big block.
Remove the liquid line and expansion valve, remove the POA and all its attachments, remove the engine side of the evap case, pull it out. Reverse. **Use new green o-rings!**
Get 3M strip caulk to seal the evap to the firewall and case, case to firewall and case to case.
oddball is offline
Old October 8th, 2021, 07:27 AM
Well I've got a BB, either way it sounds easier than I was thinking. Another item to add to the winter project list.
thanks
Old October 9th, 2021, 11:36 AM
Did you have to remove the inner wheel arch to get at the lower nots?
Steve
Old October 9th, 2021, 12:10 PM
mister442's Avatar
I didn't need to but you are working by feel only. total of 7 bolts 2 studs.
Old October 9th, 2021, 02:24 PM
Just so I'm clear, the heater core will require removing the under dash section?
Steve
Old October 9th, 2021, 03:21 PM
mister442's Avatar
no it will not. If you p.m. me we can exchange numbers and I can enplane the steps needed.
Old October 10th, 2021, 07:49 PM
oddball's Avatar
Steve
Replacing just the evap coil only requires removing the engine side cover in the engine compartment.
Replacing the heater core requires removing the inside heater box. Note there are long studs that go from the heater box through the firewall with nuts on the engine side. A good look at the assembly manual is very useful here.
oddball is offline
Old May 5th, 2024, 04:18 PM
Ron Gardner's Avatar
How did you make out? I need to do this now on my 1969 455 and the engine side cover will not clear and come off. I saw another post saying remove it with the entire box.
Ron Gardner is offline
Old May 5th, 2024, 04:58 PM
I was able to remove the cover by itself but I did replace the heater core as well. So I took both sides off. The nut on the firewall nesr the distributer was difficult. I think I tied a string to a wrench so when I dropped it I didn't have to go under the car. I also would up removing the wheel arch so I had more access. I was all very tight and difficult to get at some things but I was able to do it.
Steve
Old May 6th, 2024, 06:09 AM
Steve
Thanks I found the same and a post that said remove the cover so today I am going to unbolt the fender side too. either remove or tilt out far enough to pull and replace the coil. Yes the lower right side is nearly impossible, great olds design engineering LOL.
Chumpy2112
September 21st, 2019 04:46 PM
pcard
March 11th, 2016 12:30 PM
501Paratrooper
December 29th, 2013 12:11 PM
66-3X2 442
September 29th, 2009 03:09 AM
ctrain22
September 6th, 2009 08:37 AM
Quick Reply: Evaporator Coil Replacement
