Heater core & evaporator advice
Old February 19th, 2018, 05:51 PM
Rodney
cdrod's Avatar
I'm close to the stage in my rebuild where I will need to reassemble the HVAC system and reinstall the evaporator suitcase. I have a a couple of questions hoping for advice from those that have gone before me.
1. Most of the replacement heater cores now are made from aluminum. Am I better off with a new aluminum core or should I have a radiator shop re-core my existing copper heater core? I will have an aluminum radiator and aluminum intake manifold, do I reduce the effects of electrolysis by installing an aluminum heat core instead of a copper core?
2. Can I pressure test the evaporator and reuse it if it tests OK, or should I replace it with a repop part? Can a radiator shop pressure test the evap core or should I take it to an AC shop?
My project has also reached critical mass in regards to the budget so saving $$ where possible is important but not if it affects dependability. Thanks!
cdrod is online now
Old March 16th, 2018, 09:34 AM
banny's Avatar
I haven't had any issues with the aluminum heater cores ive installed in the heater boxes that I restored. You can flush and pressure test the original evap. I do it many times. Just have to check with shops if they can do it. Some my gm restored units https://www.youtube.com/playlist?lis...FKMMKfybxmuIeJ
banny is offline
Old March 17th, 2018, 12:27 PM
ropewrench's Avatar
summit racing
Summit sales a copper core
ropewrench is offline
501Paratrooper
April 23rd, 2014 06:26 PM
westside807
April 21st, 2014 02:20 PM
1arunem
September 3rd, 2013 07:32 PM
Lady72nRob71
July 30th, 2011 08:14 PM
jeffs 89 cutlass salon
October 22nd, 2007 12:46 PM
Quick Reply: Heater core & evaporator advice
