info on oldsmobile hearse/ambulance
Old August 2nd, 2004, 11:33 AM
jon
jon's Avatar
Post
I'm working on a project some might find strange. But i need some info on a 1963 oldsmobile hearse/ambulance and the engine that is in it. The air cleaner has SKY ROCKET across the top middle and then ULTRA HIGH COMPRESSION around the edge. Is this a 394? Also on the driver side wheel hub is a plate with Cotner-Bevington mabey the coach company? It has model,paint,serial and date. Any info on this would be very helpful thanks
jon
jon is offline
Old August 2nd, 2004, 07:42 PM
jdorour's Avatar
Post
If the engine is original it is a 394CID. It should be the 330HP 98 engine. Cotner-Bevington was the coatch builder. Check with the OCA. There is a Professional Car Club afiliated with the OCA. They will have all kinds of info on your car.
jdorour is offline
65B01Delta
May 10th, 2013 10:56 AM
brokeandugly21
Ninety-Eight
April 5th, 2011 06:56 PM
sx455raidercelticfan
August 1st, 2010 08:03 PM
cadfan1959
August 8th, 2009 02:53 AM
laszlo
Ninety-Eight
June 19th, 2009 06:22 AM
Quick Reply: info on oldsmobile hearse/ambulance
