Old car/gas smell.
Old August 14th, 2012, 11:22 AM
No Dr. but play 1 on TV
Benton Quest's Avatar
Old car/gas smell.
Hi All,
I have a 1970 442 and it runs great. I'm very pleased with it's performance.
It idles low at stops and seems like it might shut off, but it never does.
My problem is it's smell. It has a little of the old car smell which I like. But it also has a light gas smell that it starting to concern me. I have not noticed it bad enough that it follows me when I get out, but still a concern.
I smell it more in the trunk that anywhere else.
Is it possible that the gas cap is loose enough to do this? It is not tight fitting like my newer cars. It just goes on and it is not snug at all.
Any thoughts and ideas will be appreciated.
Thanks,
BQ
Benton Quest is offline
Old August 14th, 2012, 11:25 AM
It may be a fuel vent line cracked, or bad gas cap, leaking main fuel line or return line if it's equipped with one.
Look under the car for leaks.
oldcutlass is online now
Old August 14th, 2012, 01:19 PM
allyolds68's Avatar
I believe there's a gas tank vent cannister (or something like that) behind the rear seat on 70's. I'd start checking there
allyolds68 is offline
Old August 14th, 2012, 01:24 PM
allyolds68's Avatar
I stole this pic from Lady72nRob71 here:
https://classicoldsmobile.com/forums...9-cutlass.html
Old August 16th, 2012, 05:50 AM
Hi,
I tightened up the gas cap today and put the smell test on it and I think it is somewhat better. I will keep a nose on it.
I could not see the canister in the trunk. Where do I need to look for it.
I also can't see any leaks what so ever from the tank.
If if doesn't go away, I will take it to a prof and ask them.
Old August 16th, 2012, 06:00 AM
sixty9olds's Avatar
1970 and lower did not have a vent "stack" as pictured- I believe that was 1971-72 only. Your vehicle will have either a vent above the tank or a fuel vapor return line (tank to fuel pump).
sixty9olds is offline
Old August 16th, 2012, 06:30 AM
hookem horns's Avatar
Gas cap should be non-vented and snug. Get a cheapo at any parts store if in doubt. The fuel gauge sending unit on top of the tank can be another weak spot, but changing requires dropping the tank. Just another idea if the vent lines are OK.
hookem horns is offline
Old August 21st, 2012, 06:24 AM
68oldscutlass's Avatar
Any update to this? I am having the same issue in my 68. Brand new tank and sending unit. I did not replace the few short rubber hoses yet like an idiot so that could be it. No leaks anywhere that I notice. Car runs great but the smell is definitely concerning.
68oldscutlass is offline
Old August 21st, 2012, 07:50 PM
The smell is weaker since I checked the loose gas cap.
I'm still going to buy another one and see if the seal is better.
It does not feel as tight as I think it should.
Old August 24th, 2012, 02:29 PM
Ok so I figured out my problem. Someone told me as I pulled into pepboys that I was dripping gas. Apparently only happened when I turned or gunned it. Where the filler neck meets the tank has a hairline crack on top. Gonna try jb weld first otherwise ill have to get another tank. Sucks. Atleast I know why I'm going through a lot of gas now, abd why it stinks!
Old August 24th, 2012, 04:23 PM
Just the facts...
BILL DEMMER's Avatar
stinks? ... i love the smell of raw gas in the morning
bill
BILL DEMMER is offline
Old August 25th, 2012, 03:57 AM
Don't get me wrong, I love the smell of gas but definitely not this much. Hoping the jb weld works for now. Starting to strip car down for body work and paint the next 2 weekends. Can't wait to get her done!
Old August 25th, 2012, 06:50 AM
JB Weld, or a similar 2-part "gas tank sealer" should work fine, so long as you clean the surface well.
That is a common failure point.
MDchanic is offline
Old August 25th, 2012, 12:22 PM
NOVICE car nut
oldsguybry's Avatar
If the seal inside the cap is all cracked and dry rotted then replace the cap
oldsguybry is offline
Old August 26th, 2012, 03:43 PM
OK, I got a new cap. Do I need a vented cap or a non vented?? It looks like the one on there is non vented. I do not want to use this one until I know.
Thanks.
fv64olds98
October 24th, 2014 07:49 PM
rhp454
Tech Editor's Desk
August 19th, 2014 12:12 PM
hurstoldz
June 8th, 2012 05:44 PM
Danny Boy
January 25th, 2010 02:05 PM
Keieljun
November 8th, 2007 01:30 PM
Quick Reply: Old car/gas smell.
