tail light lens question
Old August 9th, 2007, 12:45 PM
shaks 442 clone's Avatar
on a 1970 cutlass
if you only install the outer lens and not the inner lens what will happen?
shaks 442 clone is offline
Old August 9th, 2007, 04:32 PM
64Rocket's Avatar
The inner is a reflector, so I would say the light will not be as bright.
Geno..
64Rocket is offline
Old August 9th, 2007, 10:59 PM
Geno..
bro im going to have to see your cutlass in person and in action
Old August 10th, 2007, 09:03 AM
Originally Posted by shaks 442 clone
on a 1970 cutlass
The inner lens is a light diffuser that spreads the light from the single filament so it appears to fill the entire lens. If you leave it out, you'll see a single small bright light in the center of the lens and the rest of the lens won't be as bright.
joe_padavano is offline
Old August 11th, 2007, 09:47 PM
what would you recommend joe? get the inners, or its not a show car leave them off?
Old August 13th, 2007, 12:53 AM
64Rocket's Avatar
I'll be at Infineon Raceway (Sears Point) on labor day. Stop on by.
Geno..
64Rocket is offline
Old August 13th, 2007, 03:40 PM
Why would you want to leave them off? The lenses were designed in to allow the tail lights to meet DOT visibility requirements. Leaving the inners off the car makes the taillights dimmer and increases your chances of being rearended.
Old August 22nd, 2007, 04:04 PM
does anyone have 4 taillights forsale????? a complete set screws gaskets inner and outter lens?
carnell71075
April 12th, 2015 04:09 PM
Aceshigh
October 9th, 2009 01:13 PM
Jamesbo
September 4th, 2009 04:27 AM
diablo76delta88
Cars Wanted
February 29th, 2004 01:13 AM
diablo76delta88
Cars Wanted
June 17th, 2003 10:09 AM
Quick Reply: tail light lens question
