Window adj?
Snap a pic of the misalignment.
Its not hard to do but it is time consuming. You will likely have to do the door window and adjust the vert top at the same time.
Everything needs to be in good shape. The door hinges, the window channel & rollers, the stops, the weather stripping, the channel seals, quarter window vertical seal etc.
Pull the front(optional) and rear seats. Pull the door and rear interior panels. You need good lighting. The top needs to be down, (edit I mean up and locked to the windshield not down stowed away in the trunk).
Then its a matter of sitting in the car and adjusting. Small adjustments and one adjustment at a time.
Mark the original location of all the adjustment points. Good time to lubricate the mechanisms too.
