Other Oldsmobiles Anything not listed above, such as F-85 (1961-1963), Firenza (1982-1988), Starfire (1961-66 and 1975-80), Omega, etc.
1961 Starfire Holiday Hardtop
Old March 31st, 2018, 03:47 AM
  #81
dutch injun's Avatar
I forgot that is true, I have retrofitted my original Starfire hubcaps to my 15" wheels, and in my case it works well..
It is in my topic:
https://classicoldsmobile.com/forums...-starfire.html
dutch injun is offline
Old March 31st, 2018, 06:15 AM
  #82
cherokeepeople's Avatar
i didn't mean to use the whole wheel cover just the 2 bar center cap.it looks like they would be a close fit to go on the pontiac 8 lugs.i have a set of 8 lugs and could measure the width of the cap opening but i don't have an olds wheel cover center cap to measure its opening.
cherokeepeople is offline
Old March 31st, 2018, 11:14 AM
  #83
Don R.'s Avatar
Neat idea. Has anyone ever tried using the complete Pontiac 8 lug brake setup on a big Olds? Is it interchangeable?
Don R. is offline
Old March 31st, 2018, 12:36 PM
  #84
i don't see why not BUT the 65-68 8 lugs use a 2 3/4 in brake shoe on front,best bet would be the early 60-62 i think they were 2 1/4 ,63 -64 2 1/2.https://www.jgrelining.com/pontiac
Old April 3rd, 2018, 06:12 PM
  #85
61Bat's Avatar
Thanks to member jollyolds I finally have the dash emblem!
61Bat is offline
Old June 20th, 2018, 06:03 AM
  #86
KQQLCAT's Avatar
I noticed in the interior pics that the rear panels haven't been changed out. Do you have them or don't they fit?
KQQLCAT is offline
Old June 20th, 2018, 09:15 AM
  #87
61Bat's Avatar
I do have a pair of really nice 62 rear panels that match the front door panels but they are too short. At some point I will have to get custom rear panels made or make them myself. If I do that I'm going to hold out until I find a pair of 61 front door panels.
61Bat is offline
Old November 25th, 2018, 06:16 PM
  #88
61Bat's Avatar
Originally Posted by cherokeepeople
ya know what i have thought would be cool?a set of pontiac 8-lugs with the 64-65 olds aluminum wheel cover center caps.
cherokeepeople I found this today and immediately remembered your post.
61Bat is offline
Old November 26th, 2018, 03:31 PM
  #89
cool.i love the 8-lugs,.i have an old 66 pontiac dealer book it's illustrated and about 60 pages and shows all the different models.it shows a 66 gto with 8-lugs,under the pic it says wheels not availible at time of printing or something like that.i would have loved to have a set on my moms old 66 gto.
Old November 30th, 2018, 10:58 PM
  #90
61Bat's Avatar
Hey guys I'm currently searching for a pair of decent rear ashtrays for a 62 Starfire WITHOUT power windows, so its just the ashtray without the integrated p/w switch. I'm not sure if the same style with the ribbed to is the same on later years so 63 or 64 may work. I do have a pair with the p/w switches in them but for now I'm staying with crank windows. Thank you.
Ohh......STILL looking for some 1961 Starfire door panels in any condition. Actually I really only need the trim unless the front panels are minty garnet red. I will need extra trim to fabricate custom rear panels as they are longer than the convertible.
61Bat is offline
Old February 17th, 2019, 11:13 AM
  #91
61Bat's Avatar
Door panels under construction
So I finally found some 61 Starfire door panels. They look way better than they are I will only be reusing the trim and using the panel for a pattern.
61Bat is offline
Old February 17th, 2019, 11:18 AM
  #92
61Bat's Avatar
I'll be using this black pvc foamboard for the panel.
61Bat is offline
Old February 17th, 2019, 12:27 PM
  #93
D. Yaros's Avatar
[QUOTE=61Bat;1139614]Hey guys I'm currently searching for a pair of decent rear ashtrays for a 62 Starfire WITHOUT power windows, so its just the ashtray without the integrated p/w switch. I'm not sure if the same style with the ribbed to is the same on later years so 63 or 64 may work. I do have a pair with the p/w switches in them but for now I'm staying with crank windows. Thank you.
If this
is what you seek, which is what I have in my 1962 Dynamic 88 conv, they are readily available as GM used it across the makes/models line.
Try eBay or OPGI
D. Yaros is offline
Old February 17th, 2019, 12:34 PM
  #94
I just noticed this thread and I love your work- looks excellent!
Greg Rogers is offline
Old February 17th, 2019, 02:53 PM
  #95
61Bat's Avatar
[QUOTE=D. Yaros;1155154]
If this
Try eBay or OPGI
The Starfire used a longer ashtray in the rear with a die cast ribbed top and an integral lighter. Very upscale; I believe it was Starfire only. All 61 Starfires and 62 Starfire convertibles would have a power window switch also. I have seen 62 Starfire coupes without pw using the ashtray I'm looking for. I'm going to assume that they are only available used. Pontiac GP might use the same ashtray.
61Bat is offline
Old February 17th, 2019, 03:00 PM
  #96
61Bat's Avatar
Like this but no pw switch.
61Bat is offline
Old February 17th, 2019, 03:06 PM
  #97
61Bat's Avatar
Thanks! I'm pretty excited to get these door panels in the works. It will help me when I fabricate the custom rear panels to match.
61Bat is offline
Old February 20th, 2019, 05:57 AM
  #98
61Bat's Avatar
SMS has the metal insert material for the center of the panel.
61Bat is offline
Old February 21st, 2019, 08:34 AM
  #99
61Bat's Avatar
Went to a GREAT little shop yesterday called Wholesale USA Upholstery supply. http://www.wholesaleusastl.com/ I walked out with 2 yards of vinyl (super close to factory color) all the metal edging, and the 1/8" dense foam for the upper section for $60!! I just want to give them some kudos because they were so helpful and the prices were very reasonable. More pictures to follow!
61Bat is offline
Old February 23rd, 2019, 02:14 PM
  #100
61Bat's Avatar
61Bat is offline
Old February 24th, 2019, 03:45 PM
  #101
61Bat's Avatar
riveted the top on after cleaning and painting it.
61Bat is offline
Old February 24th, 2019, 03:47 PM
  #102
61Bat's Avatar
First layer of foam.
61Bat is offline
Old February 24th, 2019, 03:49 PM
  #103
61Bat's Avatar
Details glued in place and an outline of the chrome trim. The outside strip will clamp the material around the edges.
61Bat is offline
Old February 24th, 2019, 03:56 PM
  #104
61Bat's Avatar
Weighing down the vinyl between the details. Tomorrow ill stretch it in place and secure it. Waiting on carpet from ACC to match the floors and i havent even ordered the mylar for the middle from SMS yet so who knows how long before they're done. Still need to do the passenger side but this was not too bad.
61Bat is offline
Old February 24th, 2019, 04:37 PM
  #105
OLDSter Ralph's Avatar
Nice "project weights".
OLDSter Ralph is offline
Old February 25th, 2019, 07:36 AM
  #106
61Bat's Avatar
61Bat is offline
Old February 25th, 2019, 03:22 PM
  #107
what caliber are your weights!!
Old February 25th, 2019, 04:09 PM
  #108
61Bat's Avatar
.45 Long Colt
61Bat is offline
Old February 26th, 2019, 09:05 AM
  #109
61Bat's Avatar
So I finally placed my order for the embossed metal Mylar for the center of the panels.....6-8 weeks and $235 for enough to do 3 door panels.....that extra material should give me enough to make my custom rear panels. That is the only way I could get it because I was told that the panels are all die cut and the rears would not be long enough for me to use. So I'm looking at the end of April or early May before I even get the material.
61Bat is offline
Old March 1st, 2019, 06:58 AM
  #110
Collector of Stray 55's
Olds Dad's Avatar
I'm curious to know what you think of the Metal Mylar...if it seems to match well
Also, have you - or do you intend to replate the plastic armrest bases? I would like to do mine but am hesitant - if you have a source that would be great if you could share it.
Your project is awesome and I love the progress.
Olds Dad is offline
Old March 1st, 2019, 11:56 AM
  #111
61Bat's Avatar
The embossed metal/mylar from SMS looks like an exact match. I just saw somewhere someone was selling a set of "NOS" precut mylar panels for $500. I thought SMS was pricey but jeez....
on the armrest bases I'm not sure yet what to do. Probably going to try and paint them with a "chrome" paint. Who replates these?
61Bat is offline
Old March 1st, 2019, 07:42 PM
  #112
Phantom Phixer
Charlie Jones's Avatar
Could these be what you are looking for ?
https://www.ebay.com/itm/1963-1964-O...0AAOSw9HZbjDdr
Ridiculously priced , but the seller is coming down in price and willing to take offers .
Charlie Jones is offline
Old March 1st, 2019, 08:52 PM
  #113
61Bat's Avatar
Yes......more than I want to pay but that is helpful I now know that 63-64 will work.
61Bat is offline
Old March 2nd, 2019, 06:00 AM
  #114
Phantom Phixer
Shoot the guy an offer . He may come back down to reality and accept it . Wouldn't hurt to try .
Old March 14th, 2019, 11:23 AM
  #115
61Bat's Avatar
Got 'em! 😀
61Bat is offline
Old March 14th, 2019, 11:26 PM
  #116
Phantom Phixer
Good for you !
Old March 31st, 2019, 10:43 AM
  #117
61Bat's Avatar
61Bat is offline
Old March 31st, 2019, 10:56 AM
  #118
61Bat's Avatar
Starting to install the ashtray assembly and the rear courtesy lights. First I carefully stripped off the covers they are nice and I want to reuse them.
61Bat is offline
Old March 31st, 2019, 11:43 AM
  #119
61Bat's Avatar
I trimmed the metal in the armrest to put the larger ashtray in. I left a couple of little tabs of metal underneath to screw it in. The old one just set inside where this one attaches with screws.
61Bat is offline
Old March 31st, 2019, 12:48 PM
  #120
61Bat's Avatar
I'll make a simple bracket to secure the courtesy lights.
61Bat is offline
Quick Reply: 1961 Starfire Holiday Hardtop
