"1963 Oldsmobile F-85 Deluxe" - Refresh & Build Begins...
My "1963 Oldsmobile F-85 Deluxe" Refresh & Build Begins...
This is a 64,000 Actual Original Miles - Survivor Car that I purchased on eBay on 03-18-21'. It got picked up yesterday in Prattville. AL., I should have it sometime this weekend.
More to follow...
More to follow...
Washed off Engine Bay, Under-Hood, Under-Carriage, as well as washed the entire Car twice. Got it in the Garage now out of the rain and pollen. I took the Full Size Deluxe Wheel Covers off and I ordered some Thin Trim Rings for the 14" Factory Steel Wheels as well as I have some Factory Take-Off 1963 Oldsmobile Poverty / Dog Dish Hub Caps coming for it as well.
*I have 5 of the original Full Size Wheel Covers For Sale here on the forum that were on the car.
Location: Hamilton, Ontario Canada and Port Charlotte FloridaFlorida
Car looks awesome! Are you happy with your purchase with all things considered? How is the interior etc? Love to see more pics. I have a 63 as well, white, red guts, 4 speed Jetfire.
Detailed the Backseat Area, Door Panels and Door Jams. Put on New Door Bumpers and New Correct Stainless Steel Door Sill Plate Screws as well as more Period Correct Floor Mats. Also found the Seat Belts tucked under the backseat. Starting on the Front today and then on to the Trunk and Engine Bay. More info. and Pictures to follow...
Your 63 F-85 is in better overall condition than my 36K mile 63 Starfire! What a great car to have! I have been doing a lot restoration work on a "to-do" list from things that just worn themselves out from time, not necessarily mileage.Car is 90% original trying to keep it that way in terms of restoring vs.replacing some of mechanical parts.
The car is absolutely beautiful, excellent purchase! Obviously the previous owner took meticulous care of it. Was it in the same ownership for years?
[QUOTE=therobski;1336871]Your 63 F-85 is in better overall condition than my 36K mile 63 Starfire! What a great car to have! I have been doing a lot restoration work on a "to-do" list from things that just worn themselves out from time, not necessarily mileage.Car is 90% original trying to keep it that way in terms of restoring vs.replacing some of mechanical parts.
Thanks! Your progress looks good! A friend of mine on here has 2 - 1964 Oldsmobile Starfire's.
I Replaced 1 - Headlight, 2 - Tail Light Bulbs, 2 - Reverse Light Bulbs, 2 - Tail Light Assemblies as mine were pitted, 1 - Drivers Side Rear Rocket F-85 Emblem as mine was broken and a New Forever Sharp Half-Wrap Steering Wheel & Hub Assembly. The Half-Wrap Color is: Khaki.
Continuing to work on the Trunk Area.
More Pictures and Information to follow...
Finished up the Trunk Area last night. Got the NOS Tail Light Assemblies & Lenses installed and Redone the F-85 Emblem as well. Will be starting on the Engine Compartment over the next few days. More Info. & Pictures to follow...
Engine Compartment So Far...
Oil & Filter Change, Antifreeze Changed, Radiator Cap, Added a Coolant Reservoir, Positive Battery Cable, Correct Factory Battery Warning Decal, Junction Block Black Boot Cover, 2 - Chrome Oil Caps & Breathers, Chrome 14"x3" Air Cleaner Assembly with Red Re-usable Air Filter, Factory Rockette 8 Air Cleaner Decal, Re-done the Vacuum Lines, Complete Tune-Up: NGK V-Power Spark Plugs, Red 8mm Mallory Spark Plug Wires, Grey Dist. Cap to match Aluminum Engine, Rotor Button, Converted the Points & Condenser to a Pertronix Electronic Ignition, Edelbrock Red Coil, Capacitor & Bracket, I custom made a Coil Bracket, 2 - Hood Bumpers, Replaced 3 of the 6 missing Fender to Hood Bumpers and Etc.
#34
Thanks for your kind words! Yes you have known me forever it seems like and you know that I am all about the Details!
I plan on having the car at the Chatham Cruise-In on Saturday, weather permitting.
#37
#40
Went on eBay and found a nice 1961 Oldsmobile F-85 Standard Steering Wheel in a brown color to match my dash and found a Horn Button Assembly on Auto Parts Obsolete in a pewter color to match my lower dash, door panels and seats. The small steering wheel assembly that I had installed was a workout when driving and turning due to the car not having P/S. Plus the aftermarket steering wheel assembly did not have the roll pin option on it to cut the turn signals off after turning and this one does like the factory intended it too.
