Other Oldsmobiles Anything not listed above, such as F-85 (1961-1963), Firenza (1982-1988), Starfire (1961-66 and 1975-80), Omega, etc.
1986 olds calais 2.5l wont start
Old September 27th, 2008, 05:42 PM
foamy's Avatar
ok i started it in the drive way drove it up to flat grond and shut it off. i proceeded to begin instalation of my new cd player. when i finished i started the car and tested it to make sure everything was working befor puting the dash back together all was good. put the dash back together and went to start it turned the key it cranked a few times then i let go. it dident start. so i tryed again no start. took the dash back out inspected everything. it all looks to be in place i mean i never unhooked anything in there other than the radio. tryed again still no start. i thohgt i flooded it. so i rolled it back down the hill to its parking spot and let it sit there for about an hour and tryed again still no start. what coulda happened here? what should i look at? this is my first oldsmobile.
foamy is offline
Old September 27th, 2008, 06:01 PM
68/70 Cutlass's Avatar
First you need to see if you are getting fire to the distibutor & plugs, if so check for fuel.
68/70 Cutlass is offline
Old September 27th, 2008, 06:27 PM
442=A perfect 10
GoodOldsGuy's Avatar
Also, I would ask you where did you grab your 12V from? Did you go anywhere near the fuse panel or ECM?
Fred
GoodOldsGuy is offline
Old September 27th, 2008, 06:46 PM
foamy's Avatar
i bought a wireing harness that u wire up to the aftermarket radio and plug into the stock radio clip. i have to wait till tomarrow to start checking things like spark and fuel cause its dark here now. the satelite radio i installed behind the glove box. power is also ran to the wireing harnes for the radio.
foamy is offline
Old September 28th, 2008, 06:06 AM
foamy's Avatar
ok closer inspection comes to show that i have no spark. its getting fuel but not getting spark. what could have happened to cause the no spark?
foamy is offline
Old September 28th, 2008, 07:27 AM
citcapp's Avatar
You might have blown the ignition fuse, or a wire slipped off a terminal. I do not have the wiring diagram for your car, but if you have the service manual their should be a diagram that will show you how to work back from your coil to find the problem. Perhaps someone else will see your question and has such a munual if you don't. Good luck
citcapp is offline
Old September 28th, 2008, 07:29 AM
You may have inadvertently blown a fuse during the installation. Check all the fuses.
joe_padavano is offline
Old September 28th, 2008, 07:41 AM
foamy's Avatar
is there another fuse panel other than the one mounted inside the car? all the fuses in the panel inside the car are good.
foamy is offline
Old September 28th, 2008, 09:58 AM
foamy's Avatar
dun dun dun further digging found the distributer to be all rusted and corroded inside. i think i found the problem.
foamy is offline
Old September 30th, 2008, 11:48 AM
foamy's Avatar
would taking the door dinger out make it not start? i took that out of there cause it was pissing me off but i dont remember if i took it out the day it stoped running or if i took it out befor that
foamy is offline
Old October 16th, 2008, 01:57 PM
foamy's Avatar
well i sold the car. someone elses problem.
foamy is offline
lmarquette
21
July 24th, 2021 02:03 PM
usa2449
February 21st, 2017 02:58 PM
robgarner
October 6th, 2014 09:52 PM
JMofIRW
September 21st, 2009 04:36 PM
Quick Reply: 1986 olds calais 2.5l wont start
