61' Starfire
61' Starfire
I just purchased a 1961 Starfire. Restroation is far along, just finishing radio, heater, windshield however AC is giving me a problem. Does anyone know a shop that could go thru the ac system from start to finish! I am in the Washington DC area.
I would suggest that you just replace everything. I haven't worked on GM AC units in quite awhile; but I imagine the parts are available but not cheap. I have been down this road several times with older AC units which had R 12 in them originally and are corroded internally. You usually end up replacing everything eventually.
When you convert R12 to R134a you need to have your compressor rebuilt, replace the hi and low pressure hoses, put in a new orifice tube, and replace the receiver/drier. The condensor and evaporator don't need to be replaced. However, on an older system (ie. one on a classic car) I think it would be a good idea to have the system flushed to make sure you don't have any crud in the condensor or evaporator.
I converted the AC on my 1990 Buick Estate Wagon as I described above and it worked like a champ. It didn't blow as cold as the factory manual said but it was might CHILLY during the middle of summer. For AC parts you should try Kanter or Fusick.
I have no personal experience with doing a conversion, but most folks I've spoken with who've done it with cars of this vintage say that in a system designed for R-12, R-134-A is just not as cold.
I put in this alternative stuff called Envirosafe.
Kyle's 77 Cutlass
January 1st, 2014 09:06 AM
Oldssupreme
February 3rd, 2013 06:26 AM
Oldssupreme
February 3rd, 2013 06:24 AM
