Other Oldsmobiles Anything not listed above, such as F-85 (1961-1963), Firenza (1982-1988), Starfire (1961-66 and 1975-80), Omega, etc.
63' F-85 wheel and tire selection
Old April 20th, 2018, 05:32 PM
matre101's Avatar
Hello everyone! I have a question that I hope one of you will have. I have a 63 F-85 and I'm getting ready to order some smoothie wheels. I'm just not sure on size. I want to put 15in rims on, but don't know how wide I can go and tire size. I guess I just need to know what the biggest wheel and tire combination I can go with without any troubles. Thanks in advance for your time!
matre101 is offline
Old April 27th, 2018, 04:35 AM
I know first hand that 215/60-15s fit fine all around on the optional factory 15" wheels. You want zero offset wheels.
joe_padavano is offline
Old May 2nd, 2018, 07:54 AM
dbaum's Avatar
Did the optional 15" wheels come with 5 studs or the regular 4, as with the 13 inch standard wheels?
dbaum is offline
Old May 2nd, 2018, 08:21 AM
Every single 1961-63 F-85/Cutlass made has a 4 x 4.5" wheel bolt pattern.
Old May 2nd, 2018, 09:09 AM
dbaum's Avatar
Does anyone out there know where I might be able to find a set of 4 x 4.5 15" rims for my 63 f-85?
Much appreciated
Dallas
Nelson BC
dbaum is offline
Old May 2nd, 2018, 09:40 AM
Much appreciated
Dallas
Nelson BC
If you're OK with aftermarket, Wheel Vintiques 12-570404
Old May 6th, 2018, 08:03 AM
dbaum's Avatar
How did you make out with your tires?
I have a 63-f85 and am about to purchase as well.
I would love to see some photos if you have any.
Thanks!
dbaum is offline
Old May 7th, 2018, 01:54 PM
dbaum's Avatar
Hey there Joe, could you have a quick peek at my purchase to be?
I just wanna make sure I'm buying the right wheels and tires for my 63 f85 before I pull the trigger.
Much appreciated
https://www.performanceplustire.com/...aef4f435342994
dbaum is offline
Old May 7th, 2018, 02:55 PM
Much appreciated
I think you will be very happy with that combo. The only thing you need to be aware of is that the stock lug nuts are LH thread on the driver side of the car and RH thread on the passenger side. I ended up swapping the lug studs on my car to all RH thread to avoid that problem.
Old May 8th, 2018, 03:44 PM
Bret F-85's Avatar
15” wheels on a 63 F85 Deluxe
Are you saying I can put 15” wheels on my 63 F85 deluxe wagon?
Bret F-85 is offline
Old May 8th, 2018, 04:39 PM
Have you not been reading the posts in this thread?
Old May 28th, 2018, 11:02 PM
carbizguy's Avatar
hey joe, was that also the factory tire size on the 15" wheel option?
carbizguy is offline
Old May 29th, 2018, 05:10 AM
215/60-15 tire size didn't exist in 1962.
The available tires were likely something like 5.90x15
EDIT: I can confirm that 5.90x15 tires are 25.62" in diameter, right between the 6.50x13 and 7.00x13 tires.
Old May 29th, 2018, 04:55 PM
carbizguy's Avatar
I appreciate your help
Old May 30th, 2018, 07:15 AM
dbaum's Avatar
15" rims
I know this is a long shot but does anyone know where I can get a sec of OEM 15" rims for my 63 f-85?
I have a set of 13's in excellent shape if anyone has a trade.
Much appreciated.
dbaum is offline
Old May 30th, 2018, 07:18 AM
Much appreciated.
It took me about five years of searching to find a set of four, two at a time. I had good luck over at AACA. Keep in mind that Skylarks used them too.
Old August 9th, 2018, 07:24 AM
Bret F-85's Avatar
F85 1963 deluxe wagon
Dave
i just purchased 12-570404 15” x 7” steel wheels from Wheel Vintiques for my 63 F85 deluxe wagon. I appears that the wheels stick out too far in the rear and the tire will rub on the wheel well. Did you have this problem?
thanks
bret
Old August 9th, 2018, 08:41 AM
matre101's Avatar
Dave
thanks
bret
I got 15x7 inch rims. They were zero offset. I put 215 75r tires on them and they barely rubbed the wheel wells in the back. I just rolled the lip of the quarter up a little bit and it is now fine.
matre101 is offline
Old August 9th, 2018, 09:57 AM
215/75-15 is a very tall tire (27.8"). I'm surprised they fit the 61-63 cars. 215/60-15 is about the same diameter as original at a little over 25"
Old August 9th, 2018, 11:24 AM
matre101's Avatar
Dave
thanks
bret
matre101 is offline
Old August 10th, 2018, 02:34 AM
Bret F-85's Avatar
I would love to see pics of your wheel tire combo.
Old August 10th, 2018, 06:35 AM
matre101's Avatar
63' F-85 with wheel vintiques 13 series smoothies
I am about to paint the centers of the wheels blue here in the next few days. So I'll post a pic when that's done.
matre101 is offline
Old August 22nd, 2018, 08:14 PM
dbaum's Avatar
Looks fantastic!
Thanks for the pic!
dbaum is offline
jhawkthebeast
Wheels and Tires
October 18th, 2018 07:15 PM
Rick nesthus
Wheels and Tires
24
August 15th, 2018 09:31 PM
1k442
November 30th, 2017 10:49 AM
JeremyTA
Wheels and Tires
April 26th, 2011 11:43 AM
scrappie
April 1st, 2009 06:16 PM
Quick Reply: 63' F-85 wheel and tire selection
